27 November, 2024, 08:48:42 AM *
Pages: [1] 2 3   Go Down
Author Topic: Fulvia fast road engine  (Read 16503 times)
rodney3010
« on: 02 June, 2010, 11:41:16 AM »
I am currently collecting bits for the restoration of my series 3 1300 coupe. after a great deal of thought I am inclined to go down the route of a fast road version with a view to mostly using for track days. I would therefore welcome any advice/links to articles/etc that there maybe out there. I've read Jai's article on race preparing - very useful, once again thanks Jai.
Anything much appreciated and if anyone has any parts surplus to requirements that may be useful please let me know
many thanks
Rodders
« Reply #1 on: 02 June, 2010, 07:35:33 PM »
...of course a "standard" Fulvia is already "fast road" spec...
...and on a track day additional straight line speed adds little if any to the experiance...
Its a different matter if racing and bored of being the slow one or back of the pack with nobody to race with.   Think carefully of the pros and cons.  Traffic isn't getting easier, petrol's not what it used to be.
Making a better noise is a different matter entirely!!
rodney3010
« Reply #2 on: 02 June, 2010, 07:55:43 PM »
I suppose the thinking comes from wanting to get the best possible out of the car. Its not my only Lancia, my Beta spider is very original and is designed to always be so. So the Fulvia can afford to be a bit of an experiement and this as much for my own education as anything else. Just what can i do to make this as good as it could be? Along the way i fully expect to have lots of discussions (and wallet inspections) to justify different options but i suppose thats half the fun of the journey. In short i want to learn about these cars and then have a car which won't embaress itself on the track. Sorry, long explaination but I'm in a real 'thirst for knowledge mode'
Rodders
« Reply #3 on: 02 June, 2010, 08:36:12 PM »
As David said - get some aural enhancement.
Open trumpets (with mesh and socks for ingress protection) are a wonderful sight for sore ears!!
« Reply #4 on: 04 June, 2010, 07:16:41 PM »
I was thinking about this today.  While a race engine is a horrible thing there is a middle ground and there are some things that can be done to an engine that result in nothing but good.  Some thoughts below in the hope that those with direct experiance will chip in.
Meanwhile if it was me I'd have a standard engine.  However I would uprate the antiroll bar, fit a cage, extinguisher, and harness.   Buckets would swap in and out in ten mins, I'd have the rear seat clip in and out easily, and I'd have rubber mats with sound deadening stuck on the back I could sling in and out.  That would make a cracking little road car, rally car, sprint and hillclimber.  For sure the "better engine" would tempt but it would make no difference to the enjoyment.
ONLY once you've worn out a few sets of tyres, and ONLY should you be the sort of person the competion bug bites hard, should you then contemplate spending the price of the car on a couple of seconds a lap improvement, getting a row further up the grid, getting those few extra points to secure a championship.  Even if the labour is all yours that engine will STILL cost the price of a car in bits and machining.
The other question people ask themselves ONCE at that point is if that's the car to modify, or should they buy another, or buy something else entirely.
At that point I ended up with children.
What is broadly termed "blue printing", a Neil Cundy type of rebuild, will take three times as long (if not more...) but yeild an engine with less friction, variations, and vibration.  It will produce more power and torque, rev more freely, and tollerate modification.   A typical "freshen up" type of engine build is fine for normal use but with any modifications it is highly likely to drop a valve, break a ring, burn a piston.  Five track day laps in standard tune is fine, but a sustained pasting is not.  If you're not going to blueprint then you need a stock of spare engines to "consume".
An oil cooler, good oil, regular changes, and some sort of air filter are "musts" to protect the investment.
Jai's inlet mod will take in cooler air and flow more freely and so - when setup on a rolling road - has the potential for more power.  Without setting up on a rolling road you might upset the fueling and destroy the engine.
A free flow exhaust can yeild more power - but if not matched to the cam can result in flat spots.  The other compromises are noise (often a good thing - but within track limits...), potentially ground clearance, and depending on the mounting a degree of harshness and boom.  It can be a horrible waste of time and money.
While a race cam will destroy the torque curve in return for more power at engine breaking revs a rally spec cam can be a good thing all round.  With the engine blue printed and the inlet/exhaust mods and setup on a rolling road the car will be driving better than standard from tickover.  The rally cam will put it back to how it was, but lift the rev limit giving a heap more power.  However its only top end power, and up there the engine life is a lot shorter and breakages much more likely.
If willing to compromise on fuel economy then there's more power and torque to be had, but its a big increase in MPG for a slight increase in performance.  Its also likely to demand a sensitive foot at light loads and lower revs.
Again if sensitive to problems, and if you are SURE of only using high octane fuel the car can be setup to take the benefit.
For the last little bit of benefit rebore to the limit.
High compression pistons are part of the "full race" package and rarely make sense otherwise.   A race cam is rubbish at low revs and the high compression pistons "restore" the actual compression ratio lost to leaving the valves open so long.  At high revs pumping losses prevent the cylinder filling so again the pistons "restore" the compression ratio.  Its complicated, and easy to get wrong.
« Reply #5 on: 04 June, 2010, 07:20:54 PM »
There's an excellent article from Martin Cliffe you should find about the modification to their race engine.
http://www.omicron.uk.com/lanciaracing/
rodney3010
« Reply #6 on: 04 June, 2010, 08:00:53 PM »
many thanks for your comments, lots to think about. I really appreciate the thought gone into this and once again reinforces the real benefits of this club!
Rodders
rodney3010
« Reply #7 on: 04 June, 2010, 08:44:05 PM »
So, if I'm reading this right, the suggestion for a car that is capable of being driven to a track and then performing well on it and then driven home again is to keep fairly standard. Its by its nature a fairly free revving unit but could benefit from a 'rally' cam. However, I'm not sure how much more stress this may put on the engine - 'the engine life is a lot shorter and breakages much more likely.' and therefore if the pay off is worth it.
Once again, many thanks david
« Reply #8 on: 05 June, 2010, 07:10:35 AM »
David's words are wise if you want your project to be like an ordinary car (which as we all know - ordinary and Lancia cannot be used in the same sentance) ie to build drive forget.
I have tried to make my 1600 sport like that and it has a Holbay tuned engine and Holbay Tornado rally cams, custom exhaust and dellortos. It is the latter that keeps the engine in fine tune and the care with which the engine was put together (not quite sure if it was as anal as blueprinting - but wasnt thrown together either). It has done 70,000 miles since, and while I have have checked the crank bearings recently (nothing found wrong), it goes on between oil anf ilter changes.
My HF1600 on the other hand is more highly strung with racing forged CPS pistons, large valve head courtesy of Paul Leclerq, bored out to 82.5, and Holbay Var1016 (equivelent what ever that is as nobody has a spec for Var1016) cams. I dont stop working on it or keeping an eagle eye on the oil pressure.....
As David says its your choice!
Jai Sharma
« Reply #9 on: 05 June, 2010, 08:17:05 AM »
I think what David suggests has a lot to recommend it.
I realise you are still thinking about what to do, but perhaps if you have not done so already, what you might find beneficial is to see if you can get a ride in, or drive of, a car that has been modified along the lines you are thinking if you want to modify extensively. David is right that a race engine (or car) is a horrible thing on the road. For example, post Fulvia, my current racer is road legal and prepared for the same HSCC series, so I would say lightly/medium modified. I have driven it to work, but you wouldn't want to too much! I can see that further mods will make it harder work on the road. It has changed in character completely from the road version. Mind you, it is pretty good on a windy lane.....
rodney3010
« Reply #10 on: 05 June, 2010, 09:40:15 AM »
Lots to think about. I'm leaning towards those with far more experience and knowledge than I - but thats what i was hoping for when I started the thread! - and it seems as if the mildly 'tuned' version seems to the best option. I'm interested in the comment that its the dellortos that keep things in fine tune Am I reading that right? I've seen these come up from time to time but get the impression they are now quite rare and expensive. Are they worth the outlay?
Lastly and not least, I know I've said this before, but thank you to those who take the time to answer what may appear to be daft questions. Going off at a tangent but I read many calssic car mags and see prices of more mundane cars (Morris Marinas) rising in value and think is Lancia a forgotten marque? I could talk/ask questions about these cars all day because of thier abilities/styling/etc and yet the vast majority of the British classic car movement don't seem to be aware they exist. This forum and those on it do a fantastic job (why isn't there an award at the AGM to the best 'poster'?)
« Reply #11 on: 05 June, 2010, 12:13:23 PM »
Prices...
With Marinas the only ones that will have survived this far will have to be good cars that have been cherished, as such a sellers market.  70s Citroens are going the same way.  VW Campers.
With Fulvias I'm somewhat relived that cheap ones still exist - a string of projects sub 1K on ebay - something with an MOT sub 3K.   However the good ones are getting expensive - plenty have sold for more than 10K now and I expect over time, as the quality of the survivors improves, that will become the norm.
However those 12K Fulvias will have cost 30K to restore...
Meanwhile there's projects and spares cars and good stocks of bits out there for 1300s at least - there's never been so much knowledge and help - they have their Top Gear fame.  Its a happy time for Fulvias.  They've always been tough and well engineered.  They're fun in traffic, fine on a motorway, nothing better on A and B roads, fabulous track and competition cars.  Comfortable, great visibility, really decent boot, a back seat for emergencies or a heap more luggage.
Who'd not want one?  ...or three...Huh?
rodney3010
« Reply #12 on: 05 June, 2010, 03:20:10 PM »
Don't tempt me! I've just convinced my wife to rearrange the garden to allow room for a new double garage. Which means space for one more project. I think it might need to be a Fulvia Zagato - purely to allow a thorough comparision between the two types you understand! Anybody got a project gathering dust that needs a good home?
« Reply #13 on: 05 June, 2010, 03:46:55 PM »
Some more "don't do as I've done" advice  Undecided
Top tip on projects 1 - as someone with two dead cars on the drive and two in the back garden - is that you spend all your time moving them out the way of each other and none actually progressing any of them.
Top tip on projects 2 - it takes a double garage to actually work on a car rather than just store.
The other problem I've given myself is planting stuff in the garden to screen the garage and project hulks and now all my spare time goes on pruning, shredding, turning compost, sweeping up leaves, sweeping up blossom, cleaning sap off the car covers...
Can we have some pictures of the project car "as is"?    Is it a car you used to run "back in the day"?
rodney3010
« Reply #14 on: 05 June, 2010, 05:22:51 PM »
The garage will be just for storage, I've a seperate workshop for the actual work. Unfortunately the Fulvia was never really suitable for the road, it was bought, 75% finished and then children/house renovation/etc came along. in theory more time now to get on and finish (re-do some bits from first time round).
When back allows I'll take some photos.
And yes, you're quite right, as my wife says, finish one project before you start another!
On the other hand.........!!!!!!
Pages: [1] 2 3   Go Up
