22 December, 2024, 05:30:20 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Fulvia
carb fuel level
Pages: [
1
Go Down
« previous
next »
Author
Topic: carb fuel level (Read 2862 times)
dhla40
carb fuel level
on:
16 October, 2010, 05:19:08 PM »
I have just started the engine on my S2 project car which has not run for ten years so as expected I am having a few problems. The carbs are solex 35-16 which should have a fuel level of 18-20mm which I assume is measured from the top face of the main body to the fuel surface , can anyone confirm this and should the floats be fitted or removed. The reason I suspect the float level is that the idle screws have to be almost shut to get a smooth idle, how many turns out is normal for a non emission carb? The other problem is on pressure checking the cooling system the pressure drops to 1psi after about two minutes, I cannot see any external leaks and looking at the waterpump drive in the cylinder block no coolant seems to be escaping. If the water pump seal has gone is this usually apparent and if so what methods are there to rectify it.
Sean
1976 1.3s coupe
1973 1.3s coupe
1982 montecarlo project
1976 alfa GT
1981 alfa spider
Re: carb fuel level
Reply #1 on:
16 October, 2010, 10:57:36 PM »
On solex's the floats are checked on a gauge/tool. Your should set idle mix around 1 turn out from shut.
If your water pump seal has gone you would see a puddle!
1998 Zeta 21. 12v
dhla40
Re: carb fuel level
Reply #2 on:
17 October, 2010, 07:57:28 AM »
Do you mean there is a witness hole on the external pump body so that if the seal is leaking coolant will escape from here?
Sean
1976 1.3s coupe
1973 1.3s coupe
1976 alfa GT
1981 alfa spider
ncundy
Re: carb fuel level
Reply #3 on:
17 October, 2010, 08:10:56 AM »
There are two underneath; at 5 and 7 o'clock. They can get blocked.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
