Can anyone tell me if I will need any special tools, cam locking tool, etc, to change the timing belts on a 16v & VIS?
Thanks.
Hi Matthew,
The only tool according to the manual is the belt tensioner tool that as far as I'm aware most people don't use anyway, if you're changing the belts you also need to change the tensioner bearings as well, these frequently seize if not changed and will throw the belts off with a lot of bent valves as a result.
You also need to be very careful with the tensioning and make sure the that they're not too tight and don't whine, I had a belt shed it's teeth on my second 1993 Vis Auto at 18,000 miles, back about 1997. I finished up with 8 bent valves, and a head rebuild which cost over £1000, just pleased that Lancia picked up most of the tab, as they agreed the belt was faulty, there was also a modification that changed the toothed wheels along with a new belt fairly late on, to overcome broken belts, didn't help me though as mine had had them fitted from new!
If you need the relevant pages from the manual please let me know.
8227
