12 January, 2025, 01:06:17 PM *
Author Topic: front hub and brake caliper  (Read 6303 times)
dhla40
« on: 18 November, 2010, 05:47:13 PM »
I am looking for a front wheel hub and RH front girling brake caliper for a S2 coupe.
Sean
1976 1.3s coupe
1973 1.3s coupe
1982 montecarlo project
1976 alfa GT
1981 alfa spider
« Reply #1 on: 18 November, 2010, 07:50:32 PM »
hi Sean,i have a front wheel hub @ 15quid +p+p i think.please send delivery address if interested best regards richard[what is wrong with your existing one?]
dhla40
« Reply #2 on: 19 November, 2010, 09:17:55 AM »
Hi Richard
My old one is slightly bent. at first I thought it was the brake disc but the runout measured on the hub is nearly .5 mm. The bearing feels ok so I am experimenting with shims between the hub and disc to try and correct it. If this fails then I will need another hub, I am near Southampton which end of the country are you?
Sean
1976 1.3s coupe
1973 1.3s coupe
1976 alfa GT
1981 alfa spider
« Reply #3 on: 19 November, 2010, 10:12:57 AM »
I cant se how this would bend before the disk as such a strong stub? Maybe the bearing needs looking at as I have found the the inner race can wear the stub and make the hub useless. It also shows the bearing is faulty but hard to see under nominal loadings such as manual inspection.
« Reply #4 on: 19 November, 2010, 05:02:47 PM »
hi Sean ,i am in west kent and work in london if that is of any use.i also have a set of four new bearings [just checked/regreased by my local lancia specialist]a brand new retaining ring and three front discs[secondhand].these are spares for my own cars but i can sell some things to pay towards my sedan project.best regards richard
dhla40
« Reply #5 on: 19 November, 2010, 06:35:37 PM »
With the hub fitted to the car and a dial gauge on the disc if I try to rock the disc there is less than .1mm movement but on rotation the runout is about .5mm. I have tried to find where the problem is by gauging the hub using a piece of glass as a surface plate, this is a bit hit and miss but seems to show the stub is about .2mm off centre. There is a slight step in the stub running surface which I thought was part of the machining but if this is meant to be smooth all the way across then this may be the problem.
Sean
1976 1.3s coupe
1973 1.3s coupe
1976 alfa GT
1981 alfa spider
« Reply #6 on: 19 November, 2010, 07:19:00 PM »
The step is your problem I am sure - esp if it is c.5-1cm width and at the inboard end. The stub should be parallel on its length.
dhla40
« Reply #7 on: 19 November, 2010, 08:18:43 PM »
Hi Richard
Have sent you a PM.
Sean
1976 1.3s coupe
1973 1.3s coupe
1976 alfa GT
1981 alfa spider
thecolonel
« Reply #8 on: 19 November, 2010, 10:42:33 PM »
Sean,
I've just sold my Fulvia c/with a load of spares there is a hub and front disc in the spares (Southampton)
I'm pretty sure the new owner will trade.
Geoff
dhla40
« Reply #9 on: 25 November, 2010, 05:17:53 PM »
All sorted, thanks Richard for the hub and thanks Tim for the tip about the wear pattern.
Sean
1976 1.3s coupe
1973 1.3s coupe
1976 alfa GT
1981 alfa spider
Page created in 0.065 seconds with 19 queries.
