Author Topic: Dedra Fuse Box  (Read 4200 times)
  • Permanent resident
Dedra Fuse Box
« on: 10 December, 2010, 12:17:20 AM »
I know it's in Italy and it's a lot of money, but when did you last see one for sale!
http://cgi.ebay.it/Centralina-Elettronica-Lancia-Dedra-/280463638614?pt=Ricambi_automobili&hash=item414cef8056
8227 8)
Angle Grinder
  • Megaposter
    • http://www.secret-scotland.com
Re: Dedra Fuse Box
« Reply #1 on: 10 December, 2010, 02:04:32 PM »
Errr... not that long ago when Phil, David and I scrapped a couple of Dedras for the Thema Dedra Consortium. In fact I may actually have let them go to the scrapper with the car as we've got several and they're seldom asked for.  ::)
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
Re: Dedra Fuse Box
« Reply #2 on: 11 December, 2010, 12:20:27 AM »
Keep hold of them mike, if anyone has a problem within the fuse box it's impossible to repair them as they are multilayered and the only thing you can do with them is change it.
Main reason for failure is that the fuse box is tilted backwards so if any water gets inside from Leaking windscreen, or even snow off of boots, it can't get out and corrodes the internals causing all sorts of problems.
I helped Jack Romano to try and sort out his Dedra a few years ago that had multiple electrical gremlins, that turned out to be caused by water lying in the fuse box, and was eventually only sorted by changing the fuse box.
If you get anymore you don't want chuck them my way, as I'd sooner hold on to them than see them scrapped, as without being able to get hold of one, a car will become a scrapper.
8227 8)
