UPDATED 29-02-08
New items are indicated with a
Last of my Beta parts, mainly Coupe with 44k miles, many will fit all.
Contact Paul through forum or directly on 01295 730610 Cheers.
PANELS FRONT LOWER PANEL A1 £30.00
BOOTLID A1 £30.00
GLASS REARSCREEN Working elements £30.00
O/S Q/LIGHT With holes £10.00
REAR O/S Q/LIGHT Complete in chrome frame £15.00
REAR N/S Q/LIGHT Complete in chrome frame £15.00
O/S DOOR £15.00
N/S DOOR £15.00
EXTERIOR TRIM VX FRONT AIR DAM Near perfect condition £50.00
FRONT BUMPER (EARLY) Excellent straight example £30.00
PAIR CHROME GUTTERS (COUPE) £7.50 each
COMPLETE S3 SIDE RUBBING STRIP SET Rear section for coupe or HPE £40.00
BOTH LONG CURVED DOOR WINDOW CHROME PIECES £5 each
COMPLETE N/S COUPE REAR LIGHT UNIT £20.00
AS ABOVE O/S WITH BROKEN CHROME FRAME £5.00
S3 FRONT BADGE (LANCIA SHIELD) £5.00
S3 BOOTLID BADGE (LANCIA SHIELD) £5.00
INTERIOR TRIM REAR SIDE PANELS (Blue twill) £5 each
PAIR OF S3 DOOR PULL HANDLES £5 each
COMPLETE CLOCKS/GAUGES SET Complete working order Shows 44k miles £25.00
CHROME FIXING STRIPS TO BOTTOM EDGE OF DOOR CARDS £5 each
ORIGINAL RED 'DOOR OPEN' LIGHTS (Replaces reflectors on doors) NEW
All variants-Nice upgrade £20.00
ROCKER SWITCHES S2/S3 ALL TYPES £0.50-1.00
CIG LIGHTERS S2/S3 FAN SWITCHES £1.00
ENGINE ANCILLARIES FAN ASSEMBLY £10.00
ELECTRONIC IGNITION UNIT £10.00
ALTERNATOR 55 AMP £20.00
DISTRIBUTOR £10.00
WEBER CARB 34DAT 1/250 Sticking choke (1600 jets) £10.00
COIL £10.00
OTHER MECHANICAL PARTS ETC FUSE BOX £20.00
MANUAL STEERING RACK Only 44k miles £20.00
WIPER MOTOR WITH COVER £20.00
WIPER MOTOR £5.00
N/S REAR HUB WITH BACKPLATE INTACT Only 44k miles £10.00
O/S REAR HUB (No backplate) Only 44k miles £5.00
ORIGINAL HORN WITH COMPRESSOR £5.00
BRAKE BIAS VALVE £5.00
PAIR OF ELECTRIC WINDOW REGULATORS £20 each
BENDIX COMPLETE CAR SET OF BRAKE PADS NEW
£20.00
MINTEX FRONT AXLE SET OF BRAKE PADS (With sensors) NEW
£12.00
CABLES NEW SPEEDO/THROTTLE/CLUTCH NEW
£7.50 each
SPEEDO/OUTER CLUTCH £5 each
OTHER S2 FL HANDBOOK ALL VARIANTS (Approx '79---'81) Good example with ribbon £10.00
SET OF FRONT AND REAR FOG LIGHTS (Aftermarket by 'Ring') Very little use With front grilles and bulbs £10.00
