22 December, 2024, 11:31:27 AM *
Author Topic: Beta parts  (Read 6322 times)
Watshot
« on: 03 December, 2006, 06:16:53 PM »
UPDATED 29-02-08 Smiley     New items are indicated with a   Smiley
Last of my Beta parts, mainly Coupe with 44k miles, many will fit all.
Contact Paul through forum or directly on 01295 730610 Cheers.
PANELS
FRONT LOWER PANEL   A1       £30.00
BOOTLID   A1                       £30.00
GLASS
REARSCREEN      Working elements    £30.00
O/S Q/LIGHT      With holes    £10.00
REAR O/S Q/LIGHT      Complete in chrome frame    £15.00
REAR N/S Q/LIGHT      Complete in chrome frame    £15.00
O/S DOOR          £15.00
N/S DOOR          £15.00
EXTERIOR TRIM
VX FRONT AIR DAM   Near perfect condition       £50.00
FRONT BUMPER (EARLY)   Excellent straight example       £30.00
PAIR CHROME GUTTERS (COUPE)          £7.50 each
COMPLETE S3 SIDE RUBBING STRIP SET      Rear section for coupe or HPE    £40.00
BOTH LONG CURVED DOOR WINDOW CHROME PIECES          £5 each
COMPLETE N/S COUPE REAR LIGHT UNIT          £20.00
AS ABOVE O/S WITH BROKEN CHROME FRAME          £5.00
S3 FRONT BADGE (LANCIA SHIELD)          £5.00
S3 BOOTLID BADGE (LANCIA SHIELD)          £5.00
INTERIOR TRIM
REAR SIDE PANELS (Blue twill)          £5 each
PAIR OF S3 DOOR PULL HANDLES          £5 each
COMPLETE CLOCKS/GAUGES SET   Complete working order   Shows 44k miles    £25.00
CHROME FIXING STRIPS TO BOTTOM EDGE OF DOOR CARDS          £5 each
ORIGINAL RED 'DOOR OPEN' LIGHTS (Replaces reflectors on doors)   NEW   Smiley    All variants-Nice upgrade    £20.00
ROCKER SWITCHES S2/S3 ALL TYPES          £0.50-1.00
CIG LIGHTERS S2/S3 FAN SWITCHES          £1.00
ENGINE ANCILLARIES
FAN ASSEMBLY                           £10.00
ELECTRONIC IGNITION UNIT          £10.00
ALTERNATOR 55 AMP          £20.00
DISTRIBUTOR          £10.00
WEBER CARB 34DAT 1/250      Sticking choke (1600 jets)    £10.00
COIL          £10.00
OTHER MECHANICAL PARTS ETC
FUSE BOX          £20.00
MANUAL STEERING RACK      Only 44k miles    £20.00
WIPER MOTOR WITH COVER          £20.00
WIPER MOTOR          £5.00
N/S REAR HUB WITH BACKPLATE INTACT      Only 44k miles    £10.00
O/S REAR HUB (No backplate)      Only 44k miles    £5.00
ORIGINAL HORN WITH COMPRESSOR          £5.00
BRAKE BIAS VALVE          £5.00
PAIR OF ELECTRIC WINDOW REGULATORS          £20 each
BENDIX COMPLETE CAR SET OF BRAKE PADS   NEW  Smiley        £20.00
MINTEX FRONT AXLE SET OF BRAKE PADS (With sensors)   NEW  Smiley        £12.00
CABLES
NEW SPEEDO/THROTTLE/CLUTCH   NEW  Smiley                         £7.50 each
SPEEDO/OUTER CLUTCH       £5 each
OTHER
S2 FL HANDBOOK ALL VARIANTS (Approx '79---'81)      Good example with ribbon    £10.00
SET OF FRONT AND REAR FOG LIGHTS (Aftermarket by 'Ring')   Very little use   With front grilles and bulbs    £10.00
« Last Edit: 29 February, 2008, 09:53:30 AM by Watshot » Logged
Watshot
« Reply #1 on: 24 February, 2007, 08:33:17 PM »
 Kiss
« Last Edit: 05 November, 2007, 05:43:14 PM by Watshot » Logged
Watshot
« Reply #2 on: 01 May, 2007, 10:24:50 PM »
 Tongue
« Last Edit: 05 November, 2007, 05:43:50 PM by Watshot » Logged
Watshot
« Reply #3 on: 23 September, 2007, 06:31:42 PM »
Updated. All parts listed above still available. Thanks.
« Last Edit: 23 September, 2007, 06:33:42 PM by Watshot » Logged
Watshot
« Reply #4 on: 29 February, 2008, 09:54:49 AM »
Bump.
neil-yaj396
Committee
« Reply #5 on: 23 July, 2008, 08:36:52 AM »
Paul
Have you still got a Beta clutch cable? I am going on holiday in the Beta next month and am desperate to find one!!
Neil
Page created in 0.052 seconds with 20 queries.
