21 December, 2024, 12:58:02 PM *
Author Topic: Washers  (Read 4893 times)
welleyes
« on: 09 January, 2011, 11:28:06 AM »
I don't think any of our local MOT testers will pass a car without washers. It is not a problem with our other cars as they have opening screens but the Aprilia seems likely to cause aggravation. Has anyone managed to fit washers unobtrusively and with a bottle that does not get in the way?
Andrew Tallack
rogerelias
MY 1600HF IN HEARTBEAT GARAGE
« Reply #1 on: 09 January, 2011, 01:24:29 PM »
This may help, when i was a MOT tester about 22 years ago, i seem to remember that i had to pass a car that came in with a washing up liquid bottle operated by the driver sitting in the driving seat, through an open window, as i had read someting in the testers manual,about something like, as long as the screen can be washed from the drivers seat that wwas ok, but since then the MOT has gone mad, not much more to test but lots more money!!
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
Triumph Bonneville t120v 1972
1968 MGC ROADSTER
1958 Series 2 Appia berlina
Sliding Pillar
« Reply #2 on: 09 January, 2011, 03:11:51 PM »
On my old Aprilia and the current Aurelia I have fitted washers, you can buy a hand operated pump and washer jets from most vintage suppliers, then I have used a small plastic bottle and put that in the battery compartment so it is hidden. It only needs a little water in it, enough to satisfy the MOT tester!!  I have mounted the pump vertically next to the steering column, so it can hardly be seen, it is arrowed in the photo. Ade.
1955 Aurelia
1961 Lamborghini
Betaboy2.0
« Reply #3 on: 09 January, 2011, 10:17:26 PM »
..... and the two wires hanging down from under dashboard Mr Rudler?? You haven't hotwired that Aurelia have you?? Is there anything you are not telling us???
'73 Beta 1600 S1 Berlina
'79 Beta 2000 S2fl Automatic Berlina
'80 Beta 2000ES S2 Berlina
'83 Beta 1600 S3 Berlina
'79 Gamma 2500 S1 Berlina
'82 Gamma 2500 S1 Coupe
'85 Gamma 2500 S2 Berlina
'82 Delta 1500
« Reply #4 on: 10 January, 2011, 10:11:50 AM »
I have done something similar with a washer from a 2CV (of which I have several lying around).
Sliding Pillar
« Reply #5 on: 10 January, 2011, 08:15:07 PM »
The Aurelia dash photo was taken some time ago when not all things were in their respective places. The two wires have now found a home and are connected under the passenger seat to an electric shock device to get rid of annoying passengers...... Mr Collins!
1955 Aurelia
1961 Lamborghini
Dilambdaman
« Reply #6 on: 11 January, 2011, 01:09:26 AM »
Modestine has an electric pump windscreen washer with only a black twin jet as evidence, the switch being one of the original ones on the dash and the bottle and pump hidden away behind the bulkhead. Not at all obvious - no one has ever commented on it.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #7 on: 11 January, 2011, 09:06:36 AM »
The wires are there to bring the (missing) rubber floor mat into a circuit such that when you go to tune the radio you get the same signal touching the dial as when you let go - Lancia thought of everything...
...or maybe they're for something else.
Page created in 0.08 seconds with 20 queries.
