Author Topic: timing belt life.  (Read 6489 times)
murf
  • Lapsed
  • Senior Member
timing belt life.
« on: 23 January, 2011, 05:34:34 PM »
My forthcoming adventure to the French Alps in the SW has prompted me to check my records on when the car last had it's timing belts/bearings changed.It turns out that I've managed to clock up 21,400kms (13,300miles) in the last year which surprised me but which then raised the question of how much life is safely left in the current belts which have now done 17,500 miles.
Having had a catastrophic failure with an 8 valve engine a couple of years back I'm trying to err on the side of caution so I would appreciate any advice on the correct interval for changing them.
Kind regards, Murf.
Lindsay
  • Guest
Re: timing belt life.
« Reply #1 on: 23 January, 2011, 06:09:29 PM »
Some recommend 24k, but personally I would run to 30k. Assuming bearings changed at the last one.
murf
  • Lapsed
  • Senior Member
« Reply #2 on: 24 January, 2011, 11:41:50 AM »
Thanks for that info Lindsay, I assume that we are talking miles here. The car is booked in with David Thomas at Codicote on Thursday for a service which will inevitably throw up some unexpected issues so I think I'll leave the belts until after the holiday.
Kind regards, Murf.
  • Permanent resident
« Reply #3 on: 24 January, 2011, 12:04:10 PM »
Pete,
I'd agree with Lindsay as long as his proviso regarding the bearings as been adhered too.
8227 8)
murf
  • Lapsed
  • Senior Member
« Reply #4 on: 24 January, 2011, 05:32:28 PM »
Hi Brian, According to a garage receipt from nine months prior to my buying the car, both belts,the two bearings and tensioner were changed. I'm going to trust that and run with whats there until I reach 24k then get David Thomas to swap them out.
Regards, Murf.
« Reply #5 on: 24 January, 2011, 08:26:08 PM »
Regards, Murf.
Pete,
sounds good to me.
8227 8)
HF_Dave
  • Megaposter
  • Rust , What Rust !! I don't See any rust !!!
« Reply #6 on: 25 January, 2011, 07:05:25 AM »
While you are on the subject,I tend to worry about the time. How long since they have been replaced ect, I fitted new belts 4000 miles ago but that was in july 2007, I do worry about the belts perishing. The bearings were changed 14000 miles ago or about seven years ago. Has any one any advice regarding this, Thanks. ??? David
My Current Cars:
1991 Thema station wagon
1989 Thema 16v
2011 Lancia Delta 3
1977 Beta sedan 2000
1975 Fulvia S3 1.3
1973 Flavia HF 2000 Coupe
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
« Reply #7 on: 25 January, 2011, 11:26:32 AM »
Dave,
You really need to change the whole lot as I believe that the length of time is important as well, and myself would never leave a belt longer than 3 years/30K, but you're really pushing your luck if if it's 7 years since you changed the bearings, irrespective of mileage, don't wish to sound like a drama queen but I'd be changing them without delay, and preferably without driving it in the meantime if at all possible, having had a belt fail (Faulty Manufacture) on my 1993 Series 3 Auto, I know from experience that the damage is extensive, when mine went about 1995 it cost well over £1000 as I had 8 bent valves, and the exhaust valves are pretty expensive let alone anything else, just glad that Fiat/Lancia picked up most of the bill.
I also had a bearing seize and broke a timing belt on a 2.0 Dedra I'd just bought and I was on the way to the garage to get the lot changed, I was lucky in that as the belt broke it got caught up in the TDC sensor which snapped off and luckily stopped the engine dead, so I got away without any further damage, but it still had to be stripped to check for damage, that is the only time I've known of when a Dedra Timing belt broke and didn't wreck the engine,
Unfortunately with Thema's and Dedra's being worth so little these days, unless you've got a really nice one you want to keep, it's an uneconomical repair.
8227 8)
