28 December, 2024, 07:04:38 AM *
Author Topic: Laser Aluminium Repair...  (Read 5555 times)
« on: 09 February, 2011, 05:44:35 PM »
Is this the answer to a Lambda block's prayer?   The video looks very impressive and I wonder if anyone has had any experience with it.
http://www.machinemart.co.uk/shop/product/details/aluminium-repair-starter-kit/path/body-repair-kits
David
williamcorke
B10
« Reply #1 on: 09 February, 2011, 06:02:38 PM »
Amazing demonstration video.
I've got an early Alfa 750 block that is U/S with a head stud turning - looks like this technology could be a much cheaper, easier (more at-home) way to fix the problem than a full strip down and machining / heli-coiling at a shop.  Might give that a go.  Looks like it could take the tension of a head bolt, and if it won't I've only wasted £25 and the cost of a head gasket.
« Last Edit: 09 February, 2011, 09:20:17 PM by williamcorke » Logged
'37 Aprilia
'50 B10
'53 B20
'68 Flavia Vignale
'55 Giulietta Sprint
S1 Land Rover
thecolonel
« Reply #2 on: 09 February, 2011, 07:32:52 PM »
I bought the kit from Frost, read the small print you have to heat the item to be repaired
and you certainly can't get enough heat into anything bulky with a blowtorch.
I gave it up as a bad job, after several rather futile attempts
Geoff
williamcorke
B10
« Reply #3 on: 09 February, 2011, 09:19:09 PM »
Would you call an engine block bulky?
Shame.  If it sounds too good to be true...
'37 Aprilia
'50 B10
'53 B20
'68 Flavia Vignale
S1 Land Rover
« Reply #4 on: 10 February, 2011, 12:59:40 AM »
I'm sure it wasn't being sold by Laser when I saw an actual demonstration at the Silverstone Classic Car Day 2 years ago, doing exactly some of what was shown in the video, including repairing threads in aluminum using only a blow torch, somewhere I have the spec sheet for this product and it has a low melting point for use with the  blowlamp, but it was as strong as shown once repaired.
I think it was a couple of Germans who were selling it at the time, and there were a lot of mightly impressed people.
I'll have a look and see if I can find the spec sheet.
« Reply #5 on: 10 February, 2011, 11:05:28 AM »
Further research.  A pdf is available at        http://www.lasertools.co.uk/news/pdf/4707_PIS.pdf     The melting point of aluminium is 660C so the block would need to be heated to 400C.   I guess you could do this with an oxyacetylene flame but it would be safer to find someone with a big oven.  The demo is on a small block not something the size of a Lambda and I would be very nervous of melting the block itself.  I will have words with my local wizards and report back.
« Reply #6 on: 10 February, 2011, 12:12:04 PM »
I saw the coke can demo at a model engineering show.  As quick and easy as in the video - if you ever needed to repair a coke can  Wink
David
Page created in 0.054 seconds with 21 queries.
