22 December, 2024, 04:14:59 AM *
Pages: 1 [2]   Go Down
Author Topic: Bleeding Aprilia brakes  (Read 11265 times)
« Reply #15 on: 13 May, 2011, 05:37:39 PM »
Quick update....
Having fitted the cylinder, I refilled the master cylinder, gave the plunger some full pulls, and to my surprise the plunger stayed up and I found I had solid brake pedal half way down without any bleeding. Early days but amazing....
JohnMillham
« Reply #16 on: 13 May, 2011, 09:17:22 PM »
But it still needs to be bled, as there's sure to be air in the system.
« Reply #17 on: 14 May, 2011, 06:51:21 AM »
Absolutely but it is a step in the right direction. But surprised there was no sponginess. The brakes work and arnt locked on.
I will start at the back having found the inspection hatch.
« Reply #18 on: 15 May, 2011, 05:40:51 PM »
Further update. Apart from finding a blocked bleed nipple at the back (never seen before) bleeding the Aprilia with its pump reservoir (and hatch access to the rear drums) is the easiest and most rewarding of any car I have worked on! Pedal really firm and right at the top. And the plunger stays up......
« Reply #19 on: 16 May, 2011, 10:07:36 AM »
The rear hatch is such a treat you'll be in there every other week seeing if the thing needs adjusting - assuming it has a mechanical adjustment as my SIII B20 had...
Are the front dampers adjustable?  I used to include that on the standard tour for people as well.
David
« Reply #20 on: 16 May, 2011, 01:54:51 PM »
Yes adjustable dampers - decarbon fulvias eat your heart out!!!
Yes rears are adjustable as well although I havnt touched them and the pedal is at the top. (just dreading a stuck piston...)
Pages: 1 [2]   Go Up
Page created in 0.045 seconds with 20 queries.
