25 November, 2024, 07:52:30 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Alternator woes
Pages: [
1
Go Down
« previous
next »
Author
Topic: Alternator woes (Read 3418 times)
ah_sprite
Alternator woes
on:
31 May, 2011, 09:04:10 AM »
Hi all
My alternator warning light is flickering when the car is running. When the car is started ,the light will go out for around 2 seconds, then begin to flicker. It's not affected by increasing engine speed.
I have a feeling the brushes are knackered - however, can this be caused by a bad connection somewhere?
Richard
ah_sprite
Re: Alternator woes
Reply #1 on:
31 May, 2011, 09:10:34 AM »
Meant to also ask - if the alternator does need replacement, is there a better (and cheaper!) modern alternative that can be used, or are originals still commonly available at motor factors? The car is an S3, by the way.
ncundy
Re: Alternator woes
Reply #2 on:
31 May, 2011, 09:17:01 AM »
You can get them rebuilt by a competent auto electrician. Moving to a more modern one is definately feasable but if you go to one with a higher output you may need to upgrade parts of the wiring loom.
Re: Alternator woes
Reply #3 on:
31 May, 2011, 10:20:11 AM »
Auto electrician is best route. They will check and replace brushes and diode pack if necessary and new bearings. If Ducillier then bearings are non standard due to the narrower shaft.
I notice my alternator light glows on my sport at night (its dim so you cant really see in day light) but I know the thing is working /charging fine. I have assumed it is a poor earth (and on the list to sort one day) as it glows a bit brighter if the indicators are used.
1998 Zeta 21. 12v
Re: Alternator woes
Reply #4 on:
31 May, 2011, 10:37:44 AM »
I would recommend a rebuild by an expert, my Duceiller alternator on my S2 was rebuilt with new parts and now looks like new, they also tested the separate regulator box which I replaced many years ago and was fine. the glowing light on the dash is usually a power earth, never sure if the that is the dashboard end or the lead that attached to the alternator or both, more like the dash I suspect. Beefing up earth leads all round is probably a good idea anyway.
386
1973 Fulvia S2 1.3
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
