14 December, 2024, 05:31:39 AM *
Pages: 1 [2] 3 4 5 6 7 ... 30   Go Down
Author Topic: flaminia  (Read 247578 times)
0 Members and 24 Guests are viewing this topic.
« Reply #15 on: 19 August, 2011, 05:40:39 PM »
dynamo:not charging so i have tried to remagnetise/repolarise and excite the dynamo[12v to D+ and ground D- and DF with drive belt removed]but the dynamo moved only poorly instead of the reqd.'spinning like an electric motor'.so seems like removal is reqd.advice welcome.best regards richard
thecolonel
« Reply #16 on: 19 August, 2011, 09:02:59 PM »
Would suggest worn brushes or possibly
field coil insulation breaking down.
« Reply #17 on: 19 August, 2011, 09:33:02 PM »
looks like a refurb then colonel
« Reply #18 on: 20 August, 2011, 06:52:10 AM »
Richard
I believe John Jenkins advertised some Flamina wheels in VL a couple of months ago.
« Reply #19 on: 20 August, 2011, 08:01:26 AM »
Richard
i have collected them from John inc new 175 400 tyre [mounted on wheel] which i have put in the boot as the spare.a fortunate find!best regards richard
« Reply #20 on: 20 August, 2011, 06:24:42 PM »
dynamo and regulator now with the local repair chaps who will see if they can fix it or if a 'new?' one is the best bet.best regards richard
LanciAlan
« Reply #21 on: 21 August, 2011, 06:39:00 PM »
Is there no end to your industry.... how did you get the dynamo out?
Alan Murphy
« Reply #22 on: 21 August, 2011, 08:26:37 PM »
hi Alan,to remove the dynamo disconnect battery ,remove the belt tensioning bolt,remove drive belt,remove water radiator securing bolts front and rear+the radiator top mount,move radiator forwards half an inch on the left side,release dynamo cradle band fastener bolt,slip dynamo forwards from cradle then label and disconnect wiring-took a morning to work out .best regards richard
williamcorke
B10
« Reply #23 on: 22 August, 2011, 12:34:03 PM »
Flam 823 engine just popped-up on ebay for £100 (starting bid).  No connection to seller...
Spare for your 'new' car, Richard?
http://www.ebay.co.uk/itm/Lancia-V6-all-alloy-Engine-/260836969111?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cbb184a97
'37 Aprilia
'50 B10
'53 B20
'68 Flavia Vignale
'55 Giulietta Sprint
S1 Land Rover
« Reply #24 on: 22 August, 2011, 02:08:52 PM »
thank you William,can you tell what size it is?best regards richard
williamcorke
B10
« Reply #25 on: 22 August, 2011, 04:14:14 PM »
Assuming the seller has written the numbers down correctly (quite possible he's not, given there are too many numbers in 82300 2145545), we can deduce that 823.00 came into the world in a left hand drive 2.5l Farina coupe of which about 3,000 were produced.
http://www.circolodellalancia.it/commenti-tecnici/flaminia/59-dati-di-produzione-di-tutte-le-flaminia.html
'37 Aprilia
'50 B10
'53 B20
'68 Flavia Vignale
S1 Land Rover
« Reply #26 on: 22 August, 2011, 05:40:01 PM »
thanks William,whats the value of the engine anyone?also this model in RHD guise seems to have been made in quite low numbers.best regards richard
« Reply #27 on: 22 August, 2011, 06:02:34 PM »
also [apologies for the repetition]its a shame these things are not often in VL etc
williamcorke
B10
« Reply #28 on: 23 August, 2011, 12:55:33 AM »
No idea what it's worth.  If it was an Aurelia engine (same, only older and not quite as well engineered) it would be 10 times that starting price for sure.  Worth more if it's not frozen, I'd say.  I bought a frozen touring 2.5 Flaminia engine for £500 about 5 years ago; probably paid too much...
If you wanted to buy a second-hand Flaminia starter motor from Italy it would probably cost 150 Euros minimum.  So there's some value in the engine / oil cooler / starter seen in the ad.
« Last Edit: 23 August, 2011, 12:57:34 AM by williamcorke » Logged
'37 Aprilia
'50 B10
'53 B20
'68 Flavia Vignale
S1 Land Rover
« Reply #29 on: 23 August, 2011, 06:36:06 AM »
I have a lovely Flaminia camshaft in excellent condition available for sale. Not sure what it is worth - make me an offer!
Pages: 1 [2] 3 4 5 6 7 ... 30   Go Up
