« Reply #435 on: 08 March, 2023, 03:20:29 PM » |
My understanding and on my setup, there isn’t a great deal of space between the top of the trumpet and air box, and therefore i have seen aftermarket ‘subbie’ trumpets to get over this problem.
. It should be noted that Lancia paid great attention to air box design. I have been told the pancake filter on Aurelias (so relevant to Flaminia) was a Helmholtz resonator tuned to 3 frequencies. Apparently you notice the (negative) difference when driving without that filter.
Jay
« Reply #436 on: 08 March, 2023, 03:35:23 PM » |
. It should be noted that Lancia paid great attention to air box design. I have been told the pancake filter on Aurelias (so relevant to Flaminia) was a Helmholtz resonator tuned to 3 frequencies. Apparently you notice the (negative) difference when driving without that filter. Very interesting, never knew that, I am far more of the old school of thought, with high flows and creating positive pressure around intakes.
Julian Wood, Kingston, London
Richard Fridd
« Reply #437 on: 10 March, 2023, 05:44:51 PM » |
So some aftermarket foam type filter systems not so good in some ways, and lack the fire hazard protection of the steel box. Thinking back to a local Flaminia engine fire, this could be a useful fire extinguisher nozzle positioning
Richard Fridd
« Reply #438 on: 08 April, 2023, 05:32:26 PM » |
I have found a 0 to 100v dc voltmeter to fit adjacent to the voltage regulator.
Richard
Richard Fridd
« Reply #439 on: 12 April, 2023, 05:37:49 PM » |
As I have been lent a dwell meter, I have put this to use. A good thing as the points gap was larger than my workshop manual specifies. Reset to 0.4mm. Thanks to Derek. I will obtain a dwell meter of my own. Also I have made a timing scale to use with my timing strobe.
« Last Edit: 12 April, 2023, 05:42:04 PM by Richard Fridd »
Richard Fridd
« Reply #440 on: 22 May, 2023, 06:01:06 PM » |
Carpets have been collected with thanks, at the excellent LMC Greenham Common event from Martin. Now fitted, and one rear footwell mat still required.
Richard
« Last Edit: 22 May, 2023, 06:04:43 PM by Richard Fridd »
Richard Fridd
« Reply #441 on: 23 May, 2023, 06:33:08 AM » |
Thanks to Martin.
Richard Fridd
« Reply #442 on: 15 July, 2023, 09:50:52 AM » |
Until the standard door catches are reliable, these secondary 'Brighton' mechanisms will provide a 'belt and braces' solution, replacing the previous elastic straps. No, the car does not have sash- cord windows.
« Last Edit: 06 September, 2023, 08:06:09 AM by Richard Fridd »
Richard Fridd
« Reply #443 on: 07 September, 2023, 07:47:10 PM » |
I have replace the plastic safety belt guides with these plated brass items.
Richard Fridd
« Reply #444 on: 23 May, 2024, 07:31:04 PM » |
A slightly different design
« Last Edit: 11 June, 2024, 03:20:25 PM by Richard Fridd »
