24 November, 2024, 11:04:23 PM *
Author Topic: Smell of Petrol  (Read 4916 times)
Kevin MacBride
« on: 21 August, 2011, 11:30:07 PM »
Out in my car recently (2000 Sedan with carb) and there is a bad petrol smell (with windows open). No apparent leaks, and no smell from 'under bonnet' with car stationary and engine running. Any ideas ?
2000 sedan
Fiat Multipla
Fiat Cinquecento
« Reply #1 on: 22 August, 2011, 07:38:01 AM »
fuel tank vent pipe secure, obstructed or anything been put against it that has crushed or kinked the pipe, I'm assuming same as Fulvia with it in the boot, fuel cap seal? Filler pipe to tank, any sign of petrol staining? sounds like your sucking the smell from the rear forward and with windows open you're getting the full benefit, does it smell with windows shut?
Dilambdaman
« Reply #2 on: 22 August, 2011, 07:48:09 AM »
Check the rear of the car. Had the same problem on a 2000 sedan which turned out to be that the rubber pipe from the tank to the pump had perished. Had it on Modestine too when I left the fuel filler cap open! Embarrassed
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
peterbaker
www.retro-speed.co.uk
« Reply #3 on: 22 August, 2011, 02:42:56 PM »
Probably done this but try looking on the ground under car for signs of dripping fuel.
Kevin MacBride
« Reply #4 on: 23 August, 2011, 05:40:36 PM »
Thanks for the advice. I think I may have it sorted. The choke cable was caught on the underside of the air filter box. I'd recently changed the filter and probably not noticed the cable, which runs through a bracket on the underside of the casing. In effect the chocke was 'on' even though the dash light indicated that it was 'off'
2000 sedan
Fiat Multipla
Fiat Cinquecento
« Reply #5 on: 23 August, 2011, 06:01:36 PM »
Hence the smell of petrol with the windows open and the smell being sucked forward, don't think I'd have come up with that in a million years Roll Eyes
Pleased you've sorted the problem.
