Author Topic: Dedra service parts required  (Read 13348 times)
Ed.
  • Lapsed
  • Member
  • Powered by Nikon
« on: 02 November, 2011, 02:23:23 PM »
New member 1st post
Have a 92 Dedra and have to change the belts/waterpump before it goes back on the road. Problem being my local motor factors have it on their system, but cant get it in, and Fiat want almost €180 for the pump. Is there anywhere in the UK who can get genuine or generic ones in. Ive looked at the likes of Eurocarparts but they are out of stock.
I am aware there are 2 types of pump as 1992 Dedras are in a 'crossover' year, so dont want to spend ages waiting on a pump to find its the wrong one! The last 4 digits of the chassis number are 2979, but can provide the full number if required
TIA
1992 Lancia Dedra 1.8 I.E. - the adventure has begun!
Angle Grinder
  • Megaposter
    • http://www.secret-scotland.com
Re: Dedra service parts required
« Reply #1 on: 02 November, 2011, 02:29:31 PM »
What engine size is your Dedra?
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
Ed.
  • Lapsed
  • Member
  • Powered by Nikon
« Reply #2 on: 02 November, 2011, 02:36:59 PM »
HF_Dave
  • Megaposter
  • Rust , What Rust !! I don't See any rust !!!
« Reply #3 on: 02 November, 2011, 09:54:05 PM »
Welcome tro the fold Ed, Is your car a cat or non-cat. Some of the Themas were Cat fitted in 1992. :)
My Current Cars:
1991 Thema station wagon
1989 Thema 16v
2011 Lancia Delta 3
1977 Beta sedan 2000
1975 Fulvia S3 1.3
1973 Flavia HF 2000 Coupe
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
Ed.
  • Lapsed
  • Member
  • Powered by Nikon
« Reply #4 on: 03 November, 2011, 11:06:11 AM »
Welcome to the fold Ed, Is your car a cat or non-cat. Some of the Themas were Cat fitted in 1992. :)
Thanks Dave (its all your fault by the way) Will have to check when the weather is a bit drier
HF_Dave
  • Megaposter
« Reply #5 on: 04 November, 2011, 07:27:44 PM »
Cat or non-cat might help determine which type of water pump . :)
My Current Cars:
1989 Thema 16v
2011 Lancia Delta 3
1975 Fulvia S3 1.3
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
  • Permanent resident
« Reply #6 on: 05 November, 2011, 01:02:45 AM »
Shouldn't need to climb underneath as you should be able to see if it has a Lambda Sensor on the front pipe section from under the bonnet.
8227 8)
Ed.
  • Lapsed
  • Member
  • Powered by Nikon
« Reply #7 on: 05 November, 2011, 02:55:47 PM »
Thanks guys - its non-cat
Ed.
  • Lapsed
  • Member
  • Powered by Nikon
« Reply #8 on: 07 November, 2011, 10:19:55 AM »
Think Ill make it easier for myself and everyone by removing said pump at the weekend!
HF_Dave
  • Megaposter
« Reply #9 on: 07 November, 2011, 10:44:31 PM »
Don't forget to mark up the belts before removal, bring the timing to TDC and tippex everything.  :) Thanks, david.
My Current Cars:
1989 Thema 16v
2011 Lancia Delta 3
1975 Fulvia S3 1.3
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
Ed.
  • Lapsed
  • Member
  • Powered by Nikon
« Reply #10 on: 12 November, 2011, 01:15:43 PM »
Is the balancing shaft timed on the 1.8 engine?
HF_Dave
  • Megaposter
« Reply #11 on: 19 November, 2011, 08:33:07 PM »
Ed, the balance shaft has to be timed, there are timing marks on the pullys. if you dont time them properly the engine will be out of balance. thanks . David  :)
My Current Cars:
1989 Thema 16v
2011 Lancia Delta 3
1975 Fulvia S3 1.3
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
Ed.
  • Lapsed
  • Member
  • Powered by Nikon
« Reply #12 on: 23 November, 2011, 11:39:05 AM »
Does not look like it will be a DEADra for much longer  :)
« Reply #13 on: 23 November, 2011, 04:28:23 PM »
Hi Ed,
Be nice to know another will make it back on to the road as they're certainly few and far between these days, if you need access to the manuals drop me an email.
8227 8)
HF_Dave
  • Megaposter
« Reply #14 on: 26 November, 2011, 12:05:00 AM »
Do you mean Dead "ED" Ra, you could go on  and on  ;D
My Current Cars:
1989 Thema 16v
2011 Lancia Delta 3
1975 Fulvia S3 1.3
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
