01 December, 2024, 02:38:49 AM *
Pages: 1 [2]   Go Down
Author Topic: BOOTLID HINGES  (Read 14475 times)
ben
« Reply #15 on: 29 February, 2012, 11:19:30 PM »
And the other even rustier one.
Note that the hinge pin holes still have the remains of sheared off hinge pins in them which is why there don't appear to be any holes!
ben
« Reply #16 on: 29 February, 2012, 11:24:17 PM »
This is the prop in its clip  in the "parked" position.
ben
« Reply #17 on: 29 February, 2012, 11:58:04 PM »
Final pic is the actual hinge on my (1937) car that I meant to put up first!
Regarding the stay or prop, from the first photo you can see that I have reinforced the drain channel where it locates to spread the load. Rather crudely I admit but I did it at least 25 years ago.
Otherwise it is as it should be on an S1 car.
Incidently it is very awkward to instal and really requires three people,two to manipulate the lid which has to be held more or less vertically to feed the hinges into their channels, and a third person inside the car to insert the hinge pins.   The bolt mod probably makes fitting easier and gives scope for adjustment---but is heavier and as I said before I don't think it is original.
« Reply #18 on: 01 March, 2012, 08:34:52 AM »
Ben
Am so glad for this... "the crude welded on" look is original.javascript:void(0);
Can you show the detail of the spring return as mine seems to be missing. It should be fairly simple to knock up a replacement.
« Reply #19 on: 01 March, 2012, 01:32:14 PM »
Is it a case of great elegance in the drawing office and "its only a hinge" on the shop floor?
ben
« Reply #20 on: 01 March, 2012, 02:38:11 PM »
This may be pushing my photographic skills over the limit but hopefully you can make it out!
ben
« Reply #21 on: 01 March, 2012, 02:50:37 PM »
It is a hairpin type spring wound around the pin that the prop is pivoted on with a leg extending along the prop and curled around it at the end of the leg.
This is all contained in a littlesheet steel "box" like a truncated pyramid with one face missing and another face cut away to allow the prop to swing through about 90 degrees.
Perhaps I should sketch it and Chugga could make a batch!
Sliding Pillar
« Reply #22 on: 01 March, 2012, 03:52:42 PM »
I can just imagine you taking those pictures Ben, boot lid balanced on your head, trying to line the camera up without the lid coming down crushing your arms! or were you also using the broom handle approach?
1955 Aurelia
1961 Lamborghini
« Reply #23 on: 01 March, 2012, 06:31:54 PM »
My spring is broken! I assume you need to take of the brake light assy to get to the pin to retract.
Ben do you have a spare hair spring for sale?? (Haha).
ben
« Reply #24 on: 01 March, 2012, 07:19:16 PM »
            It was the broom handle method Ade.
            And sorry Tim---just sold the last one!    And yes the head of the pivot pin is behind the number-plate light.
            This makes an interesting diversion from getting my red Integrale back on its wheels after having the head off to install some new exhaust valves.Should be ready for a test run tomorrow.
chugga boom
Non-LMC Seller
« Reply #25 on: 02 March, 2012, 10:02:43 AM »
thankyou all for the posts and info, i nipped down to Ron Francis's last night and picked up the remains of a bootlid as a pattern, ron was very oppolgetic about its condition but its got hinges AND A STAY!!! its absolutly ideal for what i need but now with the photo's you have all provided i can sort ot what i've actually got  Grin
1935 augusta lusso (chugga)
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
195? appia camioncino
1972 fulvia 1600HF
1976 fulvia coupe
« Reply #26 on: 12 April, 2012, 07:06:56 AM »
Slightly different perspective, but a photo showing what I found when I removed the number plate. The bare area is immediately over the bracket for the stay and was caused by flexing in the bracket ie the paint cracked and then water got under the paint and started to rust.
Just thinking that if you are remaking the bootlid it may be worth adding a larger plate to spread the load
St Volumex
Owner of RetroPart
« Reply #27 on: 12 April, 2012, 04:50:11 PM »
If you'd like some new springs and hinges made let me know.
See www.facebook.com/RetroPart
Guy McDougall
Rare Parts for Rare Machines
Pages: 1 [2]   Go Up
