Angle Grinder
« on: 26 July, 2012, 09:33:46 AM » |
My heater control valve has developed a leak and appears to be losing water from the top of the valve where the shaft of the lever goes through the top cover plate.
If I leave the valve open, it doesn't seem to leak or at least it leaks very little, but with the valve shut there is a steady drip.
Leaving the valve open all the time is not a favoured option as my car has a new heater matrix and it really works very well so you soon heat up in summer (such as it is). My question is whether or not anyone has experience of overhauling these valves?
From other threads on this forum, I have the impression that there is some sort of diaphragm within the control valve and I guess the lever action of the valve translates into the flexing of this diaphragm. If that is the case, my diaphragm may have perished.
Just looking for some guidance before I start dismantling the valve as I suspect there will be some crumbling pieces inside.
Previous cars: 1983 Prisma 1600 1991 Thema 16v i.e. SE 1988 Thema 8v Turbo 1992 Thema 16v i.e. 1983 Gamma Coupe (manual) 1993 Thema VIS 1994 Thema VIS LE 1990 Thema 2.8
St Volumex
Owner of RetroPart
« Reply #1 on: 26 July, 2012, 01:28:48 PM » |
Yes, there is a diaphragm inside which is open and shut by a spiral groove in the lever which engages a pin and moves slightly up and down - the valve is similar to those on the Appia.
I may be able to help you with NEW original parts.
Regards,
Guy McDougall www.facebook.com/RetroPartRare Parts for Rare Machines Appia Coupé S3 (Rosina), Appia Berlina S3 (La Giaconda), Fulvia 1.3S 5 spd coupé (Tigger, belongs to Carol), Beta Spyder S2 (Vivaldi), Montecarlo Spyder S2, HPE VX (Pugsly) etc
Angle Grinder
« Reply #2 on: 26 July, 2012, 06:14:45 PM » |
So it isn't likely that I'll be able to repair this then? Sounds like the seal between the "worm" mechanism and the diaphragm must have gone. I'll see if I can dismantle it and maybe effect some sort of temporary repair
« Reply #3 on: 26 July, 2012, 08:24:31 PM » |
Looks the same as my spare for my Series 1 Fulvia Berlina that I'm looking at, originally back in 1999 Omicron carried the diagphrams to repair these so worth checking with them. Brian 8227 .
Angle Grinder
« Reply #4 on: 27 July, 2012, 10:27:58 AM » |
You're right Brian. Omicron have them for £15.41 plus vat & postage.
Angle Grinder
« Reply #5 on: 29 July, 2012, 04:30:22 PM » |
Fixed!!! Easy fix too... £21 for a wee piece of rubber from Omicron... loosen 4 x 7mm nuts underneath valve... unscrew 4 screws on top cover (taking care not to lose nuts)... slip off nasty perished 45 yr old (?) piece of rubber... prise new rubber diaphragm onto plunger... re-assemble... test and smile!!! If only modern cars were this easy to work on!
« Reply #6 on: 29 July, 2012, 11:33:45 PM » |
Fixed!!! Easy fix too... £21 for a wee piece of rubber from Omicron... loosen 4 x 7mm nuts underneath valve... unscrew 4 screws on top cover (taking care not to lose nuts)... slip off nasty perished 45 yr old (?) piece of rubber... prise new rubber diaphragm onto plunger... re-assemble... test and smile!!! If only modern cars were this easy to work on! Hi Mike, Pleased to see you've fixed the problem and while I know it wasn't cheap buy, but what would you done if one wasn't available whatever the cost Brian 8227
HF_Dave
« Reply #7 on: 01 August, 2012, 10:24:17 PM » |
On my HF Coupe the valve has been replaced with a water valve just like the one you find behind the washing machine in your kitchen ! I bought the car with this mod and it has worked fine as the cable to operate it sits in the slot of the lever and works very well. I don't think I would have come up with that idea myself. I must admit I was impressed when I saw it.
My Current Cars:
St Volumex
Owner of RetroPart
« Reply #8 on: 03 August, 2012, 05:31:32 AM » |
Hi Mike, Pleased to see you've fixed the problem and while I know it wasn't cheap buy, but what would you done if one wasn't available whatever the cost Brian 8227 Brian, if they were not available www.facebook.com/RetroPart would be making them, and ours are half that price...
« Reply #9 on: 03 August, 2012, 07:26:56 AM » |
Hi Mike, Pleased to see you've fixed the problem and while I know it wasn't cheap buy, but what would you done if one wasn't available whatever the cost Brian 8227 Brian, if they were not available www.facebook.com/RetroPart would be making them, and ours are half that price... Guy, sorry I should have course mentioned retropart as well. Brian 8227
