22 December, 2024, 02:21:29 AM *
Pages: 1 ... 4 5 6 7 8 [9] 10 11 12 13 14 ... 24   Go Down
Author Topic: The Portuguese Aurelia B12 .....and so the journey begins..........  (Read 183298 times)
« Reply #120 on: 30 January, 2013, 07:10:19 PM »
The inner bearing retaining nut is off, I wasn't there to witness the engineering genius that was required....but the story about getting it off was good. Red wrench applied, bracing between both hubs, tool applied with 10 foot lever, three segemental "cracks" and off she came.....sweet as a nut!
The outer retaining nut has defeated our home made C spanner due to the softness of the metal, even though re-inforced. So hoping to get a commercial one in the next few days.
« Last Edit: 03 February, 2013, 06:30:05 PM by Parisien » Logged
« Reply #121 on: 30 January, 2013, 09:06:36 PM »
Well done Frank, even though it was not you personally that was victorious !!!!  Good luck with an up-rated C spanner and then please let us know the state of the bearing !!!!
Look out for the O ring type seal on the outer retaining nut, I have yet to remake these although the bearing assemblies have been rebuilt and simply need torquing up.
« Reply #122 on: 30 January, 2013, 10:07:15 PM »
We were seriously doubting the left handed thread on the left hub and vice versa on the right one, such was the exasperation!
Will do re the seals, will be going down tomorrow evening if he can get one
« Reply #123 on: 30 January, 2013, 10:55:58 PM »
Epic!!  How many would be thinking "perhaps the nut doesn't need to come off after all..."
« Reply #124 on: 31 January, 2013, 09:35:29 AM »
David,
         Jim and I  never got to the 'perhaps the nut doesn't need to come off after all ....' stage. We both, independently, took it as a challenge to our effort and ingenuity to 'defeat the bloody thing and show it who is the boss !!!!. Our next move, had we not succeeded, would have been to get it hot, very hot, cherry red hot and then beat the crap out of it. By the way, the latter phrase is an old English engineering term !!  After that, if still defeated, would have come the 'perhaps the nut doesn't need to come off after all ....' phase.
However, by then that would not have been an option as all the beating and heating will have meant that, no matter what the state of the bearing, seals etc was before we started, they now most definitely must be removed !!!  Don't you just hate it when that happens !!
« Reply #125 on: 31 January, 2013, 09:41:54 AM »
Oh for the days of thicker grease, turning the radio up and thinking 'this car will be dead soon anyway'.
« Reply #126 on: 31 January, 2013, 02:54:04 PM »
Been there, done that !!!!  and in your neck of the woods David, when at college I lived in Lee High Road !!!!!
« Reply #127 on: 31 January, 2013, 03:40:23 PM »
We didn't do a lot of beating Andy....just a lot of swearing.......nor was it glowing like a furnace......just enough to ease things....Smiley
ncundy
« Reply #128 on: 03 February, 2013, 01:20:43 PM »
Was discussing this with my dad this morning, and he says the reason you are probably having so much trouble with the ring nuts is that you are using bars which are too long and not stiff enough.
The best length is about 8" with a cross section of about 2.5" x 3/8" welded securely on the back of the tool all located by a through bolt (as you have done). You then have a very stiff and strong lever which you can tickle with a lump hammer. Only for really recalcitrant cases you may need to play a flame on it.
Putting them back is the reverse, tickle it with the hammer until it goes solid, then tap it round to get the next locating ring hole aligned. Torque values are rather meaningless in this type of assembly (fine thread - wide diameter).
« Reply #129 on: 03 February, 2013, 02:33:03 PM »
Neil, thanks for that gem of information, will pass it onto my guy tomorrow
« Reply #130 on: 03 February, 2013, 06:34:05 PM »
Next is the outer retaining nut.....again, spent some time to no avail, the C spanner made in, as it turns out, not the hardest of metal, bent twice despite re-inforcing. With Neils ideas plus my guys ingenuity, we with move it all on tomorrow
« Last Edit: 03 February, 2013, 06:36:45 PM by Parisien » Logged
« Reply #131 on: 04 February, 2013, 08:06:03 PM »
Modified and greatly strengthened C spanner worked a treat......about 10 seconds of effort, complete bearing assembly removed, cleaned then re-assembled. A local motor factors boasts he can provide any bearing under the sun.........sounds like hes going to eat some humble pie shortly.....Wink
Will post up some pics too
Tomorrow, swing car around to loosened other assembly up, continue to strip doors
« Last Edit: 04 February, 2013, 08:46:01 PM by Parisien » Logged
« Reply #132 on: 06 February, 2013, 08:33:25 PM »
Best laid plans and all that, - no problems getting the 2nd inner retaining nut off on the other side, used a thick beam with small bottle jack to maintain constant pressure on bearing tool, a bit of heat and 10mins later off.
As for the outer retaining nut, broke the tooth off the C spanner 3 times, plus the C shape of the tool got deformed, tool then substantially re-inforced, a bit of heat and all done, we didn't take bearing out as we need to stick wheels back on to move to body man in a few weeks time, but delighted with ourselves tonight!
No more this week, glass out next week, more tidying......
« Reply #133 on: 06 February, 2013, 08:43:26 PM »
Bravo ! - like the bottle jack solution
« Reply #134 on: 06 February, 2013, 08:47:17 PM »
That little thing was a god send, he'd cobbled it together with another part for a specific purpose....the bearing tool moved too much, so lost quite a bit of the torque action...it worked well!
Pages: 1 ... 4 5 6 7 8 [9] 10 11 12 13 14 ... 24   Go Up
