the.cern
« Reply #270 on: 24 April, 2016, 07:14:37 PM » |
That is brilliant Frank!!! Real progress on both body and engine fronts.
I am pleased that you are at the 'putting it back together' stage. I have yet to hear whether the second head from my engine may be saved!!
Good luck with it all and have a great day on Friday.
Andy
Parisien
« Reply #271 on: 24 June, 2016, 09:06:43 AM » |
In light of Chris's thread, just a fuller update, my engine is progressing, a few issues raised their ugly heads, but in an engine which hadn't any protection for 65yrs, they weren'tnt the biggest of surprises plus its now a much older engine than those rebuilt in the 80/90s.
A lot of accessing and clearing of all channels, tubes and nooks and crannies was required.
So, liners all in, crank and camshafts in, now replacing a few more bushes to allow remainder of build to take place, have to wait a week for those, they then need fettling before fitting.
So the next few weeks should see an end in sight bar any other hiccups.
P
PS Tried posting some pics off my phone but couldn't.
Frank Gallagher
Parisien
« Reply #272 on: 30 June, 2016, 05:26:36 PM » |
Take 2, 3 or 4, forgotten how many times I've attempted to upload some pics!
First batch...
P
Frank Gallagher
Parisien
« Reply #273 on: 30 June, 2016, 05:32:00 PM » |
More body pics........he said he would have it in primer shortly, shall I run a sweepstake about the likelihood?!
P
PS Apols for lasts gratuitous photo!
Frank Gallagher
Parisien
« Reply #274 on: 30 June, 2016, 05:39:06 PM » |
And now a few of the engine.
There have been a number of niggly and unforeseen issues which have added delays running into 3/4 weeks over the last few months which I wont go into, but hoping we are on the home straight now.
There was the slightest of wear in the con rod bearings so a new batch gotten off Omicron to speed things up and they've been sent off for reaming as required. Also a slight difference in cam followers which may need some adjusting too!
P
Frank Gallagher
Parisien
« Reply #275 on: 30 June, 2016, 05:41:34 PM » |
More.
P
Frank Gallagher
Parisien
« Reply #276 on: 14 July, 2016, 10:06:16 PM » |
Things are motoring along now.......bottom end completed, some fettling of studs etc on top of block then heads will finally be back in place!
P
Frank Gallagher
Parisien
« Reply #277 on: 14 July, 2016, 10:08:31 PM » |
And........
P
Frank Gallagher
« Reply #278 on: 14 July, 2016, 10:11:01 PM » |
Delays of 3/4 weeks - I've been waiting on an Aprilia engine for 18 months .....
Looking great !
Parisien
« Reply #279 on: 14 July, 2016, 10:12:18 PM » |
...last batch.......
Meanwhile my body/paint guy hasn't been so industrious......ie nothing much done since last report!
P
Frank Gallagher
« Reply #280 on: 14 July, 2016, 11:43:16 PM » |
What a work of art...
Parisien
« Reply #281 on: 15 July, 2016, 07:16:17 AM » |
Well the Tate gallery aint getting it! James has taken get care and lavished great attention to this rebuild, am very pleased P
Frank Gallagher
the.cern
« Reply #282 on: 15 July, 2016, 02:48:49 PM » |
You spelt Tate incorrectly!!!!
Andy (Tait)
Parisien
« Reply #283 on: 14 August, 2016, 05:52:30 PM » |
S*D the Olympics!
Once again, James rises above the humdrum of what goes on in the rest of the world..........just fabulous......
P
Frank Gallagher
Parisien
« Reply #284 on: 14 August, 2016, 05:56:04 PM » |
Quoting off Jame's Facebook ...plus taking the photos from there too.......
"Today I decided to do some work on the Aurelia engine, the bottom end was near complete however we have changed the original worn out steel cam followers for cast iron type which don't suffer as badly for wear, the iron followers are shorter overall length however have a thicker Base, this and the fact that the heads and block have been skimmed caused uncertainty with valve clearance so I decided to build the engine with old used gaskets first to make sure I could get tappet clearance comfortably, once satisfied I stripped it down again and rebuilt with new gaskets, 3 of the special domed head nuts are knackered so I have used ordinary m8x1 nuts temporarily until replacements are sourced"
P
Frank Gallagher
