26 November, 2024, 05:49:10 AM *
Pages: [1] 2   Go Down
Author Topic: Brake servo  (Read 15291 times)
« on: 23 October, 2012, 02:16:22 PM »
Next problem.  The servo on my series II Sport 1600 is not functioning.  Omicron do not have recon. kits but Cavallito sells a diaphragm and various folks on Ebay sell recon. kits for series IIa Girling servos as fitted to various British cars of the 60s.  Can anyone tell me what type of servo is fitted to my car (apart from Girling, that is!)?  The alternative is to fit a servo and master cylinder from another car - has anyone done this?  I have asked Amadei for a quote for a complete servo and await with bated breath for the shock.
« Reply #1 on: 23 October, 2012, 05:26:58 PM »
Bonaldi Italy. Dont know they come apart. Have you tried second hand? Alternatively try Roberto at Spitline! http://spitline.com/scheda.asp?id=10644 (this is the part - seems on an exchange basis but not expensive)....
« Reply #2 on: 02 November, 2012, 10:55:06 AM »
Yes, also http://lancia.cc/?page=article/catalog&catalog=Catalogue%20Fulvia.  Trouble is, international carriage for return (2.6 Kg) costs £60!  Anyone know a way round that one?
« Reply #3 on: 02 November, 2012, 11:08:46 AM »
http://www.parcel2go.com/?ad=priceled&gclid=COy2x_SDma8CFYpjfAodHCNO1w
Could try these guys
ncundy
« Reply #4 on: 02 November, 2012, 12:46:53 PM »
I don't recall repairing the servos was any great difficulty. It's a while since I've done one but there's not a lot to them. As I recall the only tricky bit is spliting the chamber without the spring flying out. I think it was a two person job with the case held in the vice, one steadying it whilst the other turned one half until the detents had unlocked.
Once apart you need to check it for rust as water collects at the bottom and can cause pin holes, although failure is almost certainly the diaphram splitting. Clean it, a good coat of etch primer and a good top coat inside and out then it should be fine.
« Reply #5 on: 02 November, 2012, 01:13:16 PM »
I think a DIY post with photos would be good on this Neil/David.......
Smiley
« Reply #6 on: 17 November, 2012, 02:42:04 PM »
I have had quite a chat by email with Felix Furtak at
http://lancia.cc/index.php
who are based in South Africa.  They can supply exchange units but the cost of transport to SA from UK is excessive so I am trying a UK firm (will report back).   He has been very helpful and attentive and it is a shame I cannot do business with him.  They have a good selection of spares for all older Lancias and could be worth a look.
I don't feel at the moment up to doing it myself and where would I get a diaphragm anyway?  Need to get on and do other Lancias so this time I will buy someone else's time!
« Reply #7 on: 01 February, 2013, 01:49:47 PM »
Just had the servo rebuilt by J&L Spares of Rochdale http://www.jlspares.com/brakeparts.htm  for £210 including vat and delivery.  It looks like new, has clearly been stripped cleaned, rebuilt and even replated.   Nice people to deal with and none of the complication and cost of sending to Italy.
« Reply #8 on: 05 March, 2013, 05:56:31 PM »
Put it on and all was well for some 20 miles.   Then the brake pedal travel became minimal, thought "Ah, no air in the brakes, fine"  Then after a few more miles, while overtaking a tractor, the brakes came on of themselves, harder and harder and I had to stop (safely past the tractor but a bit embarrassing nonetheless).  I slackened the joints of the pipes at the master cylinder to release the pressure and re-tightened and went home on the handbrake (who needs brakes anyway?).   This morning put her in the garage and started her up and tried the brakes a number of times and they felt totally normal.  Anyone any ideas please?   The chap from J&L spares did not think it was likely to be the servo (but offered to retest it anyway).
« Reply #9 on: 05 March, 2013, 06:33:16 PM »
check the actuating rod as the length can be sensitive and provide the symptoms you describe. Never had this my self but have heard lf it on Fulvias.....
Interest ingly I reversed my HF out of the Garage after a longish rest over winter and back down the drive and the brake pedal went to the floor when trying to stop.  Pulled handbrake on and pumped the pedal a couple of times a it now feels like normal.
« Reply #10 on: 06 March, 2013, 12:41:16 PM »
I agree with Tim: even a very minor change in the actuating rod length can produce the problem you had. This is manifested when the underbonnet temperature goes up and induces a slight increment in the overall length enough to block the brakes. You will have to reset the system by reducing the rod extension by 2-3 mm. However, it can be a matter of trial and error. Andrea
« Reply #11 on: 06 March, 2013, 02:14:41 PM »
I have experienced this problem in a friend's S2, especially on warm days when the car will become virtually undriveable as you destroy the front brake pads, let the car cool down (several hours) and the brakes free off or release the pressure on the master cylinder, he has rebuilt the master cylinder, rebuilt the calipers, replaced the front flexible pipes to no avail.  Another Fulvia driver in the UK had the same problem, they read of a similar problem with another make of car and make some adjustments and the problem has not re-occurred since shorting the rod length to the top of the pedal.
I have just sent my master cylinder and servo to be reconditioned by J&L, the parts arrived today and will carefully measuring the rod before refitting to the car as per the manual's recommended length.
386
1973 Fulvia S2 1.3
ColinMarr
« Reply #12 on: 06 March, 2013, 06:21:27 PM »
I have experienced this as well. The early warning of the brakes about to bind-on being less and less free movement of the pedal. Shortening the rod by half a turn of the adjuster solved the problem for me. And fixing it lying upside down with your head in the footwell in the dark and in the rain is such fun!
Colin
« Reply #13 on: 06 March, 2013, 10:10:51 PM »
Colin, you get all the fun !!!!!!!!
There is nothing like necessity to force the issue, in your case dark and rain were not sufficient to prevent you  from successfully addressing the issue.
This, 'I will succeed' attitude is I feel sure what binds we of the LMC together. Well done !!
« Reply #14 on: 07 March, 2013, 10:10:28 AM »
At least I was able to do this in the garage in the dry.   Seems logical, have done same, brakes now come on at a comfortable half pedal and so far so good.  Thank you Gentlemen!
Pages: [1] 2   Go Up
