26 November, 2024, 06:21:38 PM *
Author Topic: Electrics and starter issues  (Read 7729 times)
kernow
« on: 19 November, 2012, 02:43:27 PM »
Hi All,
Nice day here Saturday so broke out the FSZ and had a great day out. Going to put the car away I tried to start the engine and nothing. The starter solenoid occasionally clicks and doesn't work but only once in a while and then engages on second go, so I assumed some sort of solenoid issue or a short as the engine was warm. First stop, give the solenoid a little encouragement with the mallet. What kind of weird contortionism is needed to get the air-box cover off?
After being able to reach the starter properly and giving it a tap - started fine. But investigating the wiring around the starter threw up the fact that the wire from the starter to the fan via the inline fuse had no fuse. Upon putting a fuse in there was a loud crackling and the fuse shorted out.
So, is there a likely culprit of the shorting fuse? Obviously was an issue before as the previous owner/garage has taken the fuse out! Could it be the fan thermostat?
Also, how big a job is swapping out the starter / solenoid?
1971 Fulvia Sport
« Reply #1 on: 19 November, 2012, 03:07:19 PM »
Chris, a Bosch starter motor I suspect, I has similar problems many year ago, a tap on the solenoid whilst a passenger turned the key is a bit of a fiddle, I had the starter overhauled in the end, I had a new solenoid as some point that was not 100% reliable either.
Not sure about the inline fuse, I will look at the wiring diagram, is there a relay in that circuit?
386
1973 Fulvia S2 1.3
« Reply #2 on: 19 November, 2012, 03:25:54 PM »
The fuse is to supply the fan which is switched to earth by the rad thermoswitch which switches the earth by a relay under the wing.
To short to earth requires a dead short in the fan.
Re starter solenoid I have taken to bits both Ducelier and Bosch starter/solenoids. Best done a combined job. If you have an old spare you can generally make a good one replacing all worn parts.
I have to take my air horn compressor out to get my air box outer of. Yes it is a bl**dy nuisance esp when you want to do a simple job like balancing the carbs.
kernow
« Reply #3 on: 19 November, 2012, 04:23:26 PM »
Ah, thanks guys - that does sound like there's a short to earth in the fan and rather than fix it they just took the fuse out.
How easy is it getting the starter off? Is it pretty straight forward - any tricks of the trade? Space isn't exactly plentiful inside the engine bay. It took me ages to find an angle where I could get the air box cover off without it fouling on something or other. Is space tighter on the Sport than Coupe?
1971 Fulvia Sport
« Reply #4 on: 19 November, 2012, 08:57:13 PM »
I have a large electrical flow diagram for the Fulvia S2/3, I have managed to scan a small part which shows the wiring for the fan and solenoid, I hope it is of some use.
* Fulvia flow chart.pdf (72.87 KB - downloaded 274 times.)
386
1973 Fulvia S2 1.3
« Reply #5 on: 19 November, 2012, 09:33:24 PM »
Starter - disconnect the battery first!! then the electrical connections and then the 2 bolts/nuts holding the starter motor to the bell housing - withdraw....
More space in a coupe for the air box.
roddy
« Reply #6 on: 19 November, 2012, 11:41:47 PM »
Hello Chris
I think your recently obtained Fulvia Sport is a Series 1.5?  If so, then the side opening bonnet is like the S1, and on the S1 Sport there is a short stay (about 5" long) that goes between the front hinge of the bonnet and the chassis leg.  It is held in place by two 6mm set-screws.  In order to get the outer half of the air-cleaner box off and out of the engine bay, you need to remove this stay completely.  Leaving it in place prevents the trumpet part of the cleaner box having sufficient clearance to allow full removal.  Also as the end of the trumpet is very close to the bulb holder of the r/h headlamp, it is wise to check after refitting that the electric connections to the headlamp are intact.
Regards - Roddy
Roddy Young
Dunfermline, Fife
1970 Fulvia Sport S1 1.3S
« Reply #7 on: 20 November, 2012, 07:51:11 AM »
Yes it is true on my later sport I have occasionally found I had a cyclops car!! Also 1600 sports engines are slightly higher with the head pushed further towards the right further aggravating the problem of removal.
kernow
« Reply #8 on: 20 November, 2012, 01:57:43 PM »
Hi Roddy,
You are right - it does foul the stay and spent about ten minutes trying to extricate the box before realising the stay needed to come out. I'll check the headlight as it did keep catching...
1971 Fulvia Sport
ColinMarr
« Reply #9 on: 24 November, 2012, 05:53:39 PM »
My Zagato is an early S1 car with sideways opening bonnet and a 1600 engine taking up most of the available space. I must have had that air-box off and on a thousand times and it never occurred to me to think that the strut is removable! For sure at first it’s a fiddle, but once you know how, it’s a doddle!
I had always thought this was just another of the ways that Mr Lancia keeps you on your toes and makes you think things through. Like with my Aprilia when I first needed to adjust the fan belt tension and was delighted to discover the quick-release radiator shell to reveal an eccentric dynamo that just needed to be rotated a bit – lovely!
Colin
kernow
« Reply #10 on: 01 December, 2012, 04:09:54 PM »
Am I right in thinking I have a Bosch starter motor - I've crawled under the car and can't see any id marks on it? It's a 1970 s1 1/5.
1971 Fulvia Sport
« Reply #11 on: 01 December, 2012, 05:24:56 PM »
It could be a ducellier. Bosch is slightly bigger I think. Bothe are easy to work on.
« Reply #12 on: 03 December, 2012, 11:19:50 AM »
And interchangeable, Andrea
Page created in 0.036 seconds with 20 queries.
