Dave...had to look again at the restoration......very impressed.
Tell me, are you skilled in any of the areas of work undertaken? The repair of the aluminium areas, how difficult etc?
Good to see you were as distraught and annoyed as I was in stripping back the underseal, both sides of the metal too!
Headlining sourced where? Ddi you get bearings removed/sourced successfully?
Did you sand blast car at all, used which rust converter and why?
Ceramic finish to manifolds, DIY or send off and to whom?
Petrol tank innards cleaner you used?
Sorry the list is a bit long...........
Oh, yes failed to spot its a Touring....ooppsss......even nicer!
Keep up the excellent work, when do you intend putting it back on the road?
