21 December, 2024, 03:49:38 PM *
Author Topic: Is Beta 2000 enging the same as Montecarolo engine.  (Read 5136 times)
HF_Dave
« on: 26 January, 2013, 09:18:44 PM »
I have been offered a 2000 engine out of a Monte for my 2000 sedan, I had a look at it the other day , started it up  and it runs fine. The owner is going to fit a V6 Alfa to the Monte and has offered the engine to me. I can see that the distributor is mounted at the top of the engine, it also has electronic ignition  that's the only external difference I can see, are the cams different ? or the pistons ? would the engine be more torque, because of it's sporting application. Thanks. David . Huh?
« Last Edit: 26 January, 2013, 09:22:29 PM by HF_Dave » Logged
My Current Cars:
1991 Thema station wagon
1989 Thema 16v
2011 Lancia Delta 3
1977 Beta sedan 2000
1975 Fulvia S3 1.3
1973 Flavia HF 2000 Coupe
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
« Reply #1 on: 26 January, 2013, 09:59:11 PM »
Sump is different too, I think the box is too but not 100% sure, It will have a hydraulic clutch instead of cable. Don't scrap the clutch lever arm if you do swap it out. There's a market for it.
St Volumex
Owner of RetroPart
« Reply #2 on: 27 January, 2013, 05:32:33 AM »
Cams are different as are the carb jettings (so the engine's more peaky), gearbox ratios are shorter with a lower top end, & a couple of casting bosses are different on the block.  The Monte sump is much better than the Beta's, but will not clear the Beta subframe on the RHS. Otherwise it should be okay.
Guy McDougall
www.facebook.com/RetroPart
Rare Parts for Rare Machines
« Reply #3 on: 27 January, 2013, 11:53:39 AM »
Are the oil pumps different too then?
HF_Dave
« Reply #4 on: 27 January, 2013, 02:04:00 PM »
I wouldn't worry about swapping the sump over also the cam box as the distributor is mounted on top of the engine . I already have bought all the parts to re-build my own engine which is a low mileage original from the car so matching numbers ect. Not that a Beta Sedan is going to be much sought after in years to come  by people fussy about matching numbers but you would never know. Its my Dads original car so I suppose IU should keep it right. What kind of value does a 42000 mile Monte engine have ? thanks. David. Smiley
My Current Cars:
1989 Thema 16v
2011 Lancia Delta 3
1975 Fulvia S3 1.3
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
St Volumex
Owner of RetroPart
« Reply #5 on: 28 January, 2013, 02:57:07 PM »
Monte & Beta oil pumps are marginally different to the naked eye, but short of measuring the flow, pressure etc. they would be interchangeably functional. Though I've never personally done a swap, it should fit into the Beta sump, & the bolt holes fixing the pump to the block are the same spacing.
Dave, I like your thinking about rebuilding your dad's Beta engine.  Smiley
Guy McDougall
HF_Dave
« Reply #6 on: 28 January, 2013, 06:08:23 PM »
I think I will take the Monte engine and keep it in stock, over the years I had a couple of HPE's and Coupes, but I got rid of all the spare parts including complete engines. The only regret was a HPE Volumex that was to rotten to save, I removed the engine separated the parts from the block including the super charger . I advertised the engine for sale and a guy called for it we did a deal for the  engine and he took it away. A few months later I was looking through the parts collection and couldn't find the supercharger. I reckon he slipped the charger into his van when I wasn't looking .  Embarrassed Don't you just hate that.!
My Current Cars:
1989 Thema 16v
2011 Lancia Delta 3
1975 Fulvia S3 1.3
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
Page created in 0.053 seconds with 20 queries.
