26 November, 2024, 02:32:31 AM *
Pages: 1 ... 4 5 6 7 8 [9] 10 11   Go Down
Author Topic: Fanalone CUC 20H  (Read 98096 times)
0 Members and 25 Guests are viewing this topic.
Dilambdaman
« Reply #120 on: 09 June, 2013, 05:19:53 PM »
Finally managed to download the photographs from my mobile phone and I thought it best to insert them in the right chronological order. So, you'll have to go back to page 6 if you want to catch up on them.
I've realized that I took none during that last week! I wonder why?!  Huh?
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #121 on: 09 June, 2013, 06:26:56 PM »
Worth the wait - thank you !
It was an amazing feat to go from zero to the Fulvia 50th in such a short time, did any of you sleep ?
« Reply #122 on: 09 June, 2013, 08:31:29 PM »
Robin, a truly astonishing feat accomplished in an incredibly short time, congratulations.
Now I hope you and Jonathon will have a wonderful summer of Lancia bliss.
 Best wishes,
williamcorke
B10
« Reply #123 on: 09 June, 2013, 09:16:43 PM »
Given the glacial pace of my projects this thread is both inspirational and depressing.  Mainly inspiration though!
Congratulations to the workers.
I decided some years ago that trying to restore cars to a deadline took the a lot of the pleasure out of the work, but having see the Lacey family prepare for Fulvia 50, all I can say is that (to borrow the US vernacular) Deadlines Rock.
William
'37 Aprilia
'50 B10
'53 B20
'68 Flavia Vignale
'55 Giulietta Sprint
S1 Land Rover
« Reply #124 on: 09 June, 2013, 11:05:08 PM »
In Nick Mason's "Into the Red" book (with a brilliant CD) he says how any rebuild takes a year unless the breakage happens in qualifying in which case its done overnight and on the grid the next morning.
The trouble with deadlines is something has got to give, and not all of us are in a position to do so...  I used to get frustrated, really frustrated, at missing deadlines until I clocked that I missed them for good reasons, because there was more important stuff I needed to be doing.
Another angle is that when you've finished one you've only got to find yourself another Wink
« Reply #125 on: 10 June, 2013, 06:38:45 AM »
Quote
Indeed, J has already told me to slow down .....
Dilambdaman
« Reply #126 on: 01 July, 2013, 10:52:38 PM »
Well, we didn't get the Fanalone to the AGM. It was suffering from what appears to be chronic fuel starvation and with no time to investigate Jonathan had no option but to leave it at home. Very disappointing. Sad
Robin.
« Last Edit: 01 July, 2013, 10:59:55 PM by Dilambdaman » Logged
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #127 on: 08 July, 2013, 09:49:15 AM »
Fit an electric pump!
http://www.fuelpumpsonline.co.uk/  (gave me very good service)
plus, of course, a pressure regulator and a couple of filters.
Dilambdaman
« Reply #128 on: 08 July, 2013, 01:24:05 PM »
Thanks for the thought David but we are already on a Facet solid state pump which has an inbuilt filter,
and a Filter King with pressure regulator.
Robin.
« Last Edit: 08 July, 2013, 01:26:40 PM by Dilambdaman » Logged
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #129 on: 08 July, 2013, 01:53:02 PM »
Robin, do you have a filter in the tank around the pickup pipe, you can get to it by removing the sump plug on the tank, it is more of a gauze than a fine filter, may be that is blocked? You need to collect the fuel if you remove the plug.  Wink
386
1973 Fulvia S2 1.3
« Reply #130 on: 08 July, 2013, 02:27:56 PM »
When I undid my tank drain plug the Bl**dy filter thing had disintegrated and the two side pieces flipped out to prevent the plug being fully removed with net result petrol sprayout side ways missing the catchment container and covering the garage floor...... You have been warned.
Anyway the filter gauze can be replaced with a nylon cylindrical changeable fuel filter found in good car accessory shops.
Dilambdaman
« Reply #131 on: 08 July, 2013, 10:46:23 PM »
Thanks Neil. The tank was drained, thoroughly flushed out, the filter cleaned and the interior coated with tank sealant during the rebuild.
Not sure where Jonathan is at with the investigation but we've ordered a set of overhaul gaskets for the carbs and the Filter King.
Robin.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #132 on: 09 July, 2013, 09:40:36 AM »
The first test might be to pump fuel into a jar at the carb inlet against the clock.
Did the fuel pressure regulator come with a screw in gauge?  I've not seen one in the metal before but stumbled on it somewhere online recently.
http://www.fuelpumpsonline.co.uk/malpassi-filter-king-fuel-pressure-regulator-85mm-clear-or-alloy-36-p.asp
« Reply #133 on: 09 July, 2013, 09:52:11 AM »
Metal filterking is for racers. Dont buy one with plastic bowl as modern fuel softens it and they leak...
Normally if the mech fuel pump is working it will deliver without need of regulation.
Dilambdaman
« Reply #134 on: 11 July, 2013, 10:23:07 PM »
Jonathan has stripped and rebuilt the 48 Dellortos using comprehensive overhaul kits, checked the pump filter, overhauled the Filter King fitting new gaskets and spring, fitted a new set of points and she's running better than ever.  Smiley Another case of not knowing which was at fault or maybe it was a mix of all.
He also machine tapered the two faces of the inlet manifold which has lowered the carbs, had the radiator re-cored reducing the height by 20mm and lowered the height of the water manifold and the temperature sender. All of  which has resulted in the bonnet shutting level with the wing tops without fouling the carbs and radiator.  Smiley
Robin.
« Last Edit: 18 July, 2013, 12:50:02 PM by Dilambdaman » Logged
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
Pages: 1 ... 4 5 6 7 8 [9] 10 11   Go Up
Page created in 0.082 seconds with 20 queries.
