These solutions with extended front pulleys must surely excessively load the tiny alternator front bearing with this bending moment, especially as you have to have the belt really tight.....
Tim, I'm inclined to agree with you and a good reason to stay with Dave's solution of modifying the dynamo with a front bearing which is designed to take the extra load.
I also like the idea of overcoming one potential problem without spoiling the appearance of the series 1 under the bonnet.
Must say though I've never had a problem sticking with the Dynamo on my 1969 1.3 Rallye Coupe, or "Fay" over the last 15 years as long as you didn't try to run everything at once, but with no heated rear window, or Radio there's not a lot else drawing power
8227
8227
