17 February, 2025, 12:33:56 PM *
Author Topic: Oil filler  (Read 2918 times)
kernow
« on: 07 May, 2013, 08:31:03 PM »
Anyone ever had an issue with the oil filler cap and the neck it screws onto? Topping up the oil on FSZ I noticed the metal 'top' spins with the plastic cap when I go to unscrew it and is a little loose. Should it be held in position by a 'crimping' of the edges or has a gasket failed?
1971 Fulvia Sport
« Reply #1 on: 07 May, 2013, 08:40:36 PM »
Perhaps solder it back together and also replace the "wire wool" type inner material  with a stainless steel baffle?
« Last Edit: 07 May, 2013, 08:42:08 PM by Richard Fridd » Logged
« Reply #2 on: 07 May, 2013, 10:18:43 PM »
believe it is brazed not soldered???
roddy
« Reply #3 on: 08 May, 2013, 10:54:27 PM »
A stainless steel 'pan scrub' from the supermarket makes quite a good separator.  There are two types of containers - one has two perforated circular plates inside, between which the separator material is placed;  the other type is completely hollow inside.
Regards - Roddy
Roddy Young
Dunfermline, Fife
1970 Fulvia Sport S1 1.3S
