Author Topic: Technical information only  (Read 49521 times)
  • Permanent resident
Re: Technical information only
« Reply #45 on: 07 April, 2024, 04:34:11 PM »
Sure I have replied to this elsewhere but cannot find it.   As compared with my car, this is normal.
Simon B
  • Member
« Reply #46 on: 25 May, 2024, 10:18:23 PM »
Accelerator roller and pivot bearing references
(Resolves sticking accelerator pedal issue)
Bearings to replace 2 rubber rollers behind pedal (item 38, see attached picture)
626 2RS Mini Deep Groove Ball Bearing Single Row (2 required)
Space out from the lever with M6 washers, 2 each side.
Accelerator pedal lever bearing (item 4)
NKI  10/20 Needle Roller Bearing with Machined Inner Ring (1 required)
The needle roller will also required some brass thrust washers either side. Fortunately it’s narrower than the original nylon bearing so there is room. I used 4 x M10 (20.5 OD) 1mm thick washers, 2 each side.
Earlier relevant posts:
http://www.lancia.myzen.co.uk/forum/index.php?topic=10614.0
http://www.lancia.myzen.co.uk/forum/index.php?topic=12505.msg89752#msg89752
http://www.lancia.myzen.co.uk/forum/index.php?topic=5078.0
« Last Edit: 26 May, 2024, 05:15:04 AM by Simon B »
GlynW
  • Member
  • Fulvia S2 1600HF (1971)
« Reply #47 on: 23 March, 2025, 06:41:07 PM »
Details of Fulvia Berlina and Coupe rustproofing points, reproduced from a contemporary publication (Tectyl, October 1970, in Swedish).
https://translate.google.co.uk/?sl=sv&tl=en&text=Bakre%20tvarforstyvning&op=translate
