27 November, 2024, 04:40:51 AM *
Pages: [1] 2   Go Down
Author Topic: Electric Fuel Pump and Filter King regulator  (Read 17829 times)
PhilJones
« on: 17 July, 2013, 06:49:22 AM »
New to the forum and recent 1973 Fulvia S2 owner (standard Solex carbs) I have been advised to fit an electric fuel pump (red top) and a Filter King filter/regulator.
These are the items I am looking at:
Pump: http://www.ebay.co.uk/itm/270965478831?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Filter: http://www.ebay.co.uk/itm/130946992468?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Would these items be suitable? Advise would be appreciated on fuel pressure, fitting location etc.
Many thanks Huh?
« Reply #1 on: 17 July, 2013, 07:24:44 AM »
I use a silver top on my Fulvia 1600 without issues. You need to regulate the pump with Filter King to max 3psi (pump may give more than this). Best done by a temporary in line pressure gauge. Unless you are going rallying etc it is best to get the glass bowl Filter King as you can see how much muck if any is coming through from an old fuel tank. Cheaper too. However, unless you have issues with your standard mechanical pump why bother to do this.
Mounting is generally on the front offside inner wheel arch inside engine bay for both items. Make sure you fuse the supply and to an on/off switch. Best to use the oem blue cavis benz cee through plastic pipe work available form Omicron IMHO.
Richard Fridd
« Reply #2 on: 17 July, 2013, 07:30:00 AM »
I have a similar pump on my Flaminia PF but branded (Facet), a Proline 1-6 PSI regulator near to the tank and a glass bowl filter near to the carburettor. 3.5PSI is recommended in my service manual.(To be measured with a pressure guage). I understand some pumps are batch tested and the aircraft pumps are individually tested. Richard
« Reply #3 on: 17 July, 2013, 09:16:08 AM »
Bought mine (for the Aprilia) from  http://www.flexolite.co.uk/catalogue.asp .  Compare prices I guess.
« Reply #4 on: 17 July, 2013, 09:34:16 AM »
Nice range from Flexolite at reasonable costs.
I bought my Glass Bowl filter King from Demon Tweeks which stopped no end of rubbish getting through to the carbs, my electric pump is different and was fitted by my garage adjacent to the fuel tank.
Just a thought would the in line fuel pipe non return valve they advertise, overcome the problem of having to prime the carbs, which as far as I was concerned was the reason for fitting an electric fuel pump in the first place?
Just compared prices of the filter King, and the ebay item is about £4 cheaper than the Flexolite, whereas it's about £10+ cheaper than Demon Tweeks.
That said I'd sooner go to Flexolite where you can also get everything else you need in one place, they are a reputable supplier who have been in business for many years.
« Last Edit: 17 July, 2013, 09:47:20 AM by fay66 » Logged
Richard Fridd
« Reply #5 on: 17 July, 2013, 10:45:36 AM »
My electric pump has overcome having to prime the carbs, although I have never objected to the engine building some oil pressure whilst waiting for fuel delivery during "cranking", the wait pro rata to engine shut-down time within reason. I enjoyed the fuel article in VL this month by Ian Marchbank, which mentions vapour lock in heat soak conditions, and I suppose an electric helps with that. Here is a twin pump set-up with figures swimming around
GG
« Reply #6 on: 18 July, 2013, 01:30:38 PM »
I have used an electronic pump in line (by the tank) to pump gas through the mech'l pump line - thus letting the regulation happen through that system. The electric pump is used to help startup and in rare cases of vapor lock (when very hot). It has the downside that all the pressure is taken through the diaphragm of the mech'l pump, if it were to fail, things would be very bad.
Two things to note:
1) check the output pressure of the mech'l pump. These can vary broadly, as they are very very sensitive to setup (gasket to block, length of push rod, etc.). Important.
2) there is the issue of carb boil over when car is stopped after running hard on hot day. Highly recommended is a return line from somewhere near the carbs to the fuel tank - just a small line, even 1 mm opening, will relieve the gas pressure and stop overflow. For anyone who has dealt with this problem (percolated gas can lead to fires!), its an easy fix. I think that the s. 2 Fulvias have this return already at the carbs - it was beginning to be implemented by car manuf. in the early 1970s, as the problem became apparent. I have one on an Aurelia (with Nardi kit) and it starts up hot as if it were a fresh cool engine - very safe and delightful, if a bit less than attractive to see extra line in the engine bay.
Geoff
B20B24
« Reply #7 on: 18 July, 2013, 03:28:06 PM »
I have to say I'm not a fan of these electric fuel pump upgrades, and in my experience Lancias do not respond well to modifications. I have removed electric pumps from my Aurelias in the past due to fueling problems and reverted to the original mechanical setups - the mechanical pumps are ultra reliable and I have never had vapour lock either (hot starting problems I had I traced to an overheating coil). The cold start takes a bit of cranking admittedly but at least you have a standard looking engine bay and a reliable car in the way the maker intended. There is of course the additional benefit of fire protection, if you are unfortunate enough to suffer an engine bay fire, once the engine stops the pump stops, unlike an electric pump which will merrily be feeding the flames if the ignition is on.
I'd refurbish what you have and forget the modification!
Clive
'58 B20 S6
'53 B20 S3
'67 Fulvia Sport
Richard Fridd
« Reply #8 on: 18 July, 2013, 03:40:18 PM »
Am I correct in thinking the mechanical pumps deliver fuel pressure pro rata to engine speed? One thing I have fitted in the past is an oil pressure switch which cuts the electrical supply to an electric fuel pump if fitted once the engine stops, and also a manual on/off switch. Richard
« Reply #9 on: 18 July, 2013, 05:07:13 PM »
If you look at a mechanical pressure gauge with mech pump, it is surprisingly constant with revs albeit very spiky at lower revs - seems it self regulates - mind you I was testing on a series 2 fulvia that has a return pipe....
Zagato
« Reply #10 on: 18 July, 2013, 08:35:23 PM »
I believe that there are electric pumps Facet etc sold for both carb (lower pressure) and injection (higher pressure) applications ... so be sure to buy the correct unit
The Filter King I use is a metal body ... and you regulate the pressure using the screw on the top of the Filter King unit .... so you do not need a separate pressure regulator ,,, but you will need to set the pressure using a separate gauge ... unless you buy the model with the built in gauge ....
If in doubt ring a Facet dealer to ensure that you are buying the correct one for your car
ben
« Reply #11 on: 21 July, 2013, 11:18:48 AM »
Just to be sure you are thoroughly confused I would further reinforce the comments from B20B24 and recommend keeping the standard mechanical fuel pump.
I have the original pump on my Aprilia and have no vapourisation issues using the cheapest fuel I can find with no additives.
In my experience it is usually ignition components(eg coils and condensers) that give up in the heat.
Incidentally the design of typical mechanical pumps is such that the fuel is delivered to the carb under the force of the spring behind the diaphragm so the delivery pressure depends only on the spring strength and not the engine speed.
The rate of fuel delivery is matched to what the engine demands by the needle valve in the carb. up to the maximum that the pump can achieve. This maximum is dependent on the frequency at which the diaphragm is oscillated by it's driving cam which is of course directly a function of the prevailing engine speed.
« Reply #12 on: 21 July, 2013, 11:53:20 PM »
My mechanical pump was changed about 7 years ago with a new one from Omicron and I've never had a problem with it since, the only reason for fitting an electric pump was to prime the carburettors, as the excessive churning over offended my mechanical sensibilities, as well as my fears of how long would the ring gear and starter motor last before giving up the ghost.
The electric pump has a switch with a warning light and other than the few seconds taken in priming, the pump is switched off.
Chas1
« Reply #13 on: 22 July, 2013, 03:54:36 AM »
My 1600 sport has an electric facet pump mounted adjacent to the coil and is purely for priming as it is switched via the choke you can't forget to switch off.  It doesn't have a regulator and starts on the button (if it doesn't you know something else needs tweaking).  The extra plumbing is a little unsightly.  Although only used for priming should a regulator be fitted?  I seem to recall old SU pumps having a 'pressure switch' built in.
Lancia Fulvia Sport
the.cern
« Reply #14 on: 22 July, 2013, 07:53:50 AM »
Both my Appia and the B20 have an electric fuel pump, that is how they were when I bought them.
The Appia pump is used solely to prime the carb for starting. I agree wholly with Brian concerning mechanical sensibilities, but also on the Appia starter that there is a bridge in the starter motor that burns out if you keep it churning for too long.
With regard to the B20, it is so long since I drove it that I cannot recall the starting procedure. However, I did receive a fairly short, but blunt lecture over the phone from Harry Manning telling me that the original mechanical pump, as fitted, was perfectly  adequate for the car, if correctly maintained and an electric pump was totally unnecessary. I have yet to decide on whether or not to retain the electric pump in the rebuild, but have not thrown it away, yet !!
                                             Andy
Pages: [1] 2   Go Up
