Hello David, good to from hear you
When I was putting my Hf back together after flood damage, when I pressed the brake pedal the front sidelights came on, I went through every earth, on the front and back, tried everything turned out to be a dodgy bulb the 2 filaments touching inside the glass, changed bulb problem solved. Good luck, and how about some pics of the car? cheers Roger
