26 December, 2024, 01:00:17 PM *
Pages: 1 [2]   Go Down
Author Topic: Idling  (Read 12789 times)
« Reply #15 on: 16 July, 2014, 10:35:31 AM »
Easy fix... it was just a case of fitting a new fuel filter and blowing through the idle jet. Purring sweetly now.  Grin
Given only 400 miles on this filter, does this imply something nasty in the fuel tank? Maybe worth draining/inspecting to see what comes out etc?
Sounds like the time to fit a filter king with the glass bowl!
Angle Grinder
« Reply #16 on: 16 July, 2014, 02:06:21 PM »
Where in the fuel system did you fit yours? In the boot at the fuel pump end, or in the engine bay? Not sure about the wisdom of a glass bowl protecting my engine from a steady supply of combustible liquid. I have an uprated electric fuel pump mounted in my boot under a metal box so it would be quite safe in there. Do you recall which model of "Filter King" you fitted Brian?
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
« Reply #17 on: 16 July, 2014, 02:56:15 PM »
Glass or metal:
https://www.merlinmotorsport.co.uk/s/fuel-system/carburettor-filters-regulators/page:1
« Reply #18 on: 16 July, 2014, 05:09:55 PM »
Mine is fitted in the engine bay, and it's a VERY Thick Glass, never had a problem in the nearly 10 years it's been fitted (July 2004) but it doesn't half stop the muck getting to the carbs, cleaned mine out a couple of weeks ago and checked the filters at the carbs, nothing had got past the filter King.
Demon Tweeks Product Code FSEFPR004 67mm Glass bowl with 6-8mm tails. price at the time was £29.95+ Vat + Carriage.
brian
« Reply #19 on: 17 July, 2014, 08:44:32 AM »
Agree about Filter King. Had one from day 1 (ie from 1981) on B10 sitting 6 inches from radiator and had no problems - heat-wise of rubbish-wise. Am now putting one on the Hands.
See my comments on Sport fuel problem and do not rely on 50p in-line plastic filters as I had 3 (one in main fuel line and another 1 before each carb) and still ended up with a clogged pair of carbs.
Brian Hands
1922 Hands Tourer
1934 Augusta standard saloon
1938 Aprilia S1 saloon
1953 Aurelia B10
1965 Flavia Sport
Angle Grinder
« Reply #20 on: 21 July, 2014, 01:01:21 PM »
Been looking into the Filter King variants that you suggest. One question, I can't find anything in the manual about the sort of fuel pressure that the Flavia Solex carb should be operating with and the Filter King appears to allow variance from 1.5 - 5 psi. Has anyone any advice on what it should be set to?
http://www.ebay.co.uk/itm/Malpassi-Filter-King-Fuel-Pressure-Regulator-Filter-1-5-To-5-Psi-With-Bracket-/261376628230?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cdb42d606
Previous cars:
1983 Prisma 1600
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
rogerelias
MY 1600HF IN HEARTBEAT GARAGE
« Reply #21 on: 21 July, 2014, 02:07:06 PM »
If it helps I have set mine on my 1600HF to 1.5psi, never had a problem.
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
Triumph Bonneville t120v 1972
1968 MGC ROADSTER
1958 Series 2 Appia berlina
« Reply #22 on: 21 July, 2014, 10:19:30 PM »
Never touched or checked  the pressure on my filter King, it was fitted as received and it was bought for the filter function to overcome the amount of rubbish from the tank, I didn't try draining the tank as I had visions of the drain plug boss tearing loose, something I didn't wish to contemplate.
Having been over the Alps & the Pyrenees  the set pressure has never proved to be a problem.
rogerelias
« Reply #23 on: 22 July, 2014, 11:10:14 AM »
I forgot to mention that I am using an electric  facet blue top pump, with the filter king.
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
1968 MGC ROADSTER
Pages: 1 [2]   Go Up
Page created in 0.09 seconds with 20 queries.
