26 December, 2024, 10:56:33 AM *
Pages: 1 [2]   Go Down
Author Topic: Alloy con rods  (Read 11920 times)
« Reply #15 on: 02 December, 2013, 11:15:44 AM »
Any news on rods?
As for the latin:
https://www.google.co.uk/#q=Semper+floreant+
David
welleyes
« Reply #16 on: 05 December, 2013, 07:46:22 PM »
No news yet. Things are moving rather slowly at the moment on the Lancia. Slightly bad planning as our other cars are open and the weather is getting cold. What am I saying? If there was any planning involved, the Lancia did it, not us.
Stuart
« Reply #17 on: 22 May, 2014, 08:12:23 PM »
See the new thread:
http://www.lancia.myzen.co.uk/forum/index.php?topic=7135.0
GG
« Reply #18 on: 23 May, 2014, 03:51:14 PM »
Had new rods made for my s.2B20 two liter motor - the originals were a bit thin and have a reputation for failing at high RPM. Had them made in Calif, and while they were much stronger, they were a bit heavier. However, the conversion to thin shell bearings eliminated the bronze shells, and so the overall weight difference wasn't much - something like 25 gms.
The trick was that the center of gravity of the weight shifted further up the conrod, and more importantly was a change in the split between that portion allocated to reciprocating weight (around the big end) and that allocated as reciprocating weight. As such, a new balancing weight was derived for use on the crank, rebalanced accordingly. Still smooth as can be.
Balance on the V4 is a bit trickier as there are still unknowns here in what is the proper formula, but the basic issue is the same: that the balancing weight used for the original crank is done with an assumption of the original piston/pin/rod, etc., and where that weight is roughly placed. Change any part of that, and some refiguring is needed.
Pages: 1 [2]   Go Up
Page created in 0.063 seconds with 20 queries.
