Author Topic: Delta HF Turbo i.e. clutch cable  (Read 7593 times)
Andy D
  • Senior Member
« on: 14 October, 2013, 01:10:28 PM »
I am trying to find out if the clutch cable for the Delta HF Turbo i.e. is unique to this model or whether it is used by other models, e.g. 1300/1500 or 8v integrale?
Can anybody help?  Thanks in advance.
1990 Delta HF Turbo i.e.
  • Permanent resident
Re: Delta HF Turbo i.e. clutch cable
« Reply #1 on: 15 October, 2013, 02:00:42 AM »
Andy,
Just had a look at eper and you need the M4 clutch cable the last part number being shown is 82462198, as all others have been superseded by this part, this part covers all 1.6 fuel injection as well as Turbo diesel.
There's a 8246183 shown for 1.1-1.3 -1.5 with carburettors but I don't think these are of use unless you can compare them pyhsically with what you currently have. while the integrale and Evo have hydraulic clutch release.
8227 8)
« Last Edit: 15 October, 2013, 02:22:40 AM by fay66 »
Andy D
  • Senior Member
« Reply #2 on: 15 October, 2013, 01:25:14 PM »
That's a big help - thanks very much Brian.  I didn't know about eper before.
« Reply #3 on: 15 October, 2013, 10:19:54 PM »
Andy,
This link will get you into the freebee one on line. click on spare parts and it will then give you the choice ofManufacturer, have a look around and if you have any questions let me know as it can be difficult sometimes determining if you have the up to date information. it's also possible to check if any other make/model in the Fiat Group uses the same part.
http://127.0.0.1:7080/navi?KEY=STARTUP
8227 8)
« Last Edit: 15 October, 2013, 10:24:26 PM by fay66 »
Andy D
  • Senior Member
« Reply #4 on: 16 October, 2013, 01:44:51 PM »
I can't get that link to work Brian.  I'll email you later on.
Thanks again, Andy
sparehead3
  • Administrator
« Reply #5 on: 16 October, 2013, 03:13:14 PM »
Brian and Andy : 127.0.0.1 is a link to your PC, not an address on the internet - try this one http://195.23.79.251:7080/navi?FORCED=true
Regards,
Steve Pilgrim
Andy D
  • Senior Member
« Reply #6 on: 16 October, 2013, 03:19:31 PM »
Thanks for stepping in Steve - I still can't get it to work in either Chrome or IE though.
« Reply #7 on: 16 October, 2013, 03:58:23 PM »
Whoops :-[ thanks Steve, that's probably why it worked when I tried it when previewing the post.
8227 8)
