26 December, 2024, 10:21:28 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Flavia
flavia cylinder-block gasket fitting
Pages: [
1
Go Down
« previous
next »
Author
Topic: flavia cylinder-block gasket fitting (Read 3656 times)
Dikappa
on:
06 December, 2013, 02:52:58 PM »
I'm about to start re-assembling the engine for my superjolly.
Today, I received a gasketset which finally seems to carry the correct 0.1mm gaskets.
This is the fourth set now, with the others having gaskets 0.15mm and even 0.20mm thick, or the third set correct thickness but too small in diameter.
So now before I proceed: is there any advise available on how to fit the gaskets? (I would use some grease, or is there a better product or should they be fitted dry?)
The gaskets are made of very thin (obviously) white glossy paper.
Any advise most welcome as I would like to get this right from the first time!
Thanks,
Koen
Dave Gee
Re: flavia cylinder-block gasket fitting
Reply #1 on:
07 December, 2013, 01:34:08 PM »
When I rebuilt my Flavia engine, I didn't use any sealer at all. I assume that the gaskets you refer to are those at the bottom of the liners and just let the cylinder heads pull down on top of the liners, having set the liners the correct distance above the block.
Dave
phil-m
Reply #2 on:
07 December, 2013, 05:26:33 PM »
Correct, they should be fitted dry and the liner standoff from the fireface (head gasket face) measured and checked against the factory settings.
Dikappa
Reply #3 on:
10 December, 2013, 07:08:33 AM »
Thanks for the advise!
phil-m
Reply #4 on:
10 December, 2013, 09:05:08 AM »
No problem, I found rebuilding a Flavia engine quite tricky. Although it is all beautifully constructed it is quite sensitive to build.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
