27 November, 2024, 02:27:08 AM *
Pages: 1 ... 4 5 6 7 8 [9] 10 11 12 13 14 ... 54   Go Down
Author Topic: Story so far series 1 resto  (Read 348806 times)
0 Members and 28 Guests are viewing this topic.
« Reply #120 on: 08 August, 2014, 09:44:38 PM »
After I had worked out the need for a feed to the + contact of the flasher can it was easy to see why it  was being shy yesterday.
« Reply #121 on: 08 August, 2014, 09:47:33 PM »
Put the speedo back in but no panel lights, fuel gauge, or dynamo light so back to the drawing board tomorrow, the wipers worked but made a horrible racket then stopped...
« Reply #122 on: 09 August, 2014, 01:22:29 PM »
Good news on the fuel gauge it gives fsd with 12v across it so it is working. stripped the sender down it is fritzed and needs the resistor rewiring might just set the gauge up to register full for now.
« Reply #123 on: 10 August, 2014, 10:05:59 AM »
The indicator flasher is quite a thing...  I'd assumed it was a simple switch you cancel yourself.
« Reply #124 on: 10 August, 2014, 12:04:05 PM »
Update
re wired the sender unit and gave it a quick test seems OK and the warning light works.
« Reply #125 on: 10 August, 2014, 12:06:24 PM »
The switch thing is ingenious but way over engineered, it will be cool to see the switch reset it self as you drive along.
« Reply #126 on: 11 August, 2014, 05:18:53 PM »
Any one know why there are 3 wires from the fuel tank sender to the gauge??? I just stuck them together as the other one I had marked up as the warning light lead. the series 2 only has 2 wires from the sender hmm... Anyway got the speedo back in with a working fuel gauge and low fuel light and also the dynamo light. I also found a gloworm masquerading as a dashboard light I assume I have put a too low wattage bulb in as at first I was convinced it was not working.
« Reply #127 on: 13 August, 2014, 09:43:53 AM »
Hi all
has anyone had a go at repairing the manual washer pump? mine is seized but ones on ebay go for £20 plus and are not the same any ideas
had visions of grinding off the cap to get inside but this will probably destroy it
« Reply #128 on: 13 August, 2014, 09:47:28 AM »
Hi all
need some gearbox oil any recommendations ?
off down to the unit to destroy/repair a washer pump. found one on ebay fits a Hillman Blimp will do for now with a bit of pipework rejigging
« Reply #129 on: 13 August, 2014, 10:37:39 AM »
check this out
http://www.formulavintage.it/shop/volante-per-appia-prima-serie/
looks brand new
« Reply #130 on: 13 August, 2014, 04:47:51 PM »
bit more done. fuel line connected, nearly there....
Had a look at the N/S brakes  as they have leaked fluid since put back on the car. The good news is it is not the wheel cylinder seals leaking but the banjos on the back plate. So I whipped the drum and backplate off and got half a turn on the banjos so that should cure the leak. More good news was no fluid had got inside the drum and destroyed my new linings Phew!!! Will get it all back tomorrow and put some new grease and seal in the hub. I will then do the other side.
« Reply #131 on: 13 August, 2014, 04:58:24 PM »
Also had a quick look at the number plate lights they are a bit knackered will look into getting them rechromed and fitting a lbulb holder inside. have left the washer pump to soak as it looks like it has limescale in it.
« Reply #132 on: 13 August, 2014, 08:18:55 PM »
Have you uprated the front brakes ? I thought that twin leading shoes were a late 3rd series thing. Chugga also commented on the problems with these brakes leaking
I had spotted the "new" steering wheels. He seems to be keeping shtum on the price though. The Aurelia ones which are very similar (made in France) are well over a thousand euros and I suspect these will be too !
Others, here on the forum, have done very good repairs for significantly less .......
Gearbox oil - I suspect a good EP 90 is the probable answer
Looking good !
« Reply #133 on: 14 August, 2014, 10:50:29 AM »
Someone in the dim and distant past had uprated the brakes, my youngest son rebuilt the other side and had no leaks guess he was a bit more brutal with those banjos! That wheel looks nice but the rest of the interior is 61 years young so it would look odd.
« Reply #134 on: 14 August, 2014, 04:49:03 PM »
checked the banjos and they have leaked more than before!!!!! got another 1/4 turn on them will see what they are like tomorrow. might be a remove clean and retighten. Chugga was right.
Pages: 1 ... 4 5 6 7 8 [9] 10 11 12 13 14 ... 54   Go Up
