27 November, 2024, 08:47:51 AM *
Pages: 1 ... 22 23 24 25 26 [27] 28 29 30 31 32 ... 54   Go Down
Author Topic: Story so far series 1 resto  (Read 349264 times)
0 Members and 26 Guests are viewing this topic.
« Reply #390 on: 16 November, 2016, 02:22:28 PM »
good news JCS is safely ensconced in a nice care home...we tried to look after him at home but my sister found if he went down she could not get him back on his feet...anyway they have chickens where he is now and we have arranged for Mum to join him in a week  so he should be fine...
« Reply #391 on: 02 December, 2016, 02:34:44 PM »
bad to worse JCS is back in hospital after a fall and a bump to the head so no progress lately
« Reply #392 on: 08 December, 2016, 05:41:21 PM »
JCS still in hospital
« Reply #393 on: 09 December, 2016, 10:41:29 AM »
I'm sorry to hear that Jim, I hope things improve soon.
« Reply #394 on: 18 December, 2016, 08:20:10 PM »
update JCS now out of hospital and back in his cosy care home where we have also managed to install Mum so touch wood they will have a nice Christmas. Must try and get the engine back before the Christmas break...wonder whayt excuse my engine man will have Hmmm....
« Reply #395 on: 20 December, 2016, 06:01:40 PM »
went to see the engine man...all shut up so I rang him and it sounded like he was at a Santa's Grotto...anyway... he did let slip the crank was done but he would have to check the progress on the block etc...he promised he would ring me...you can guess what happened next. I will try again tomorrow in between the gasman coming and going to the dentist.
« Reply #396 on: 05 January, 2017, 07:46:32 PM »
Got to see the engine man...he is a bit confused re the plugs in the crankshaft..he has done 2 but says the other two on the webs don't go anywhere. I dug out a diagram of the lubrication system in colour and took it over for him to peruse...watch this space
« Reply #397 on: 09 January, 2017, 10:12:08 AM »
update
the engine man is going to replace the core plug things and pressure test the block he says...
« Reply #398 on: 21 January, 2017, 01:17:31 PM »
Well the "clean" room is ready for the engine rebuild but the engine man is still holding on to it..next Wednesday he tells me he has done the 4 core plugs and needs to pressure test the block then there are 2 plugs in the crank..
« Reply #399 on: 31 January, 2017, 06:34:16 PM »
JCS back in hospital and now has pneumonia...will go and see the engine man tomorrow because my loan car (with a big boot) is going back and I will struggle to get the block etc in the boot of the Beetle Cabriolet
« Reply #400 on: 31 January, 2017, 08:48:13 PM »
Sorry to see your father is unwell again Jim.
Good luck with the engine man!!!!
« Reply #401 on: 08 February, 2017, 11:58:12 AM »
Hi all...got to see the engine man, he informs me that one of the core plugs in the bottom of the block is leaking and we need another one so dropped one off this morning. he might actually know what he is doing.
####### STOP PRESS#######
he said it will be ready for Friday!
here's hoping
Dikappa
« Reply #402 on: 08 February, 2017, 12:43:08 PM »
Hi Clarkey,
I would change them all as they tend to rot from the not visibel side...and if one is bad I would'nt thrust any of 'm...now you're at it it's a very small job...
« Reply #403 on: 08 February, 2017, 12:48:40 PM »
it was one of the replacement ones that was leaking he had put 4 new ones in and when he tested the block for pressure one of the new plugs was losing pressure so he now has a another new one to put in....fingers crossed he will be done for Friday
Jaydub
« Reply #404 on: 10 February, 2017, 06:11:14 PM »
Ref your core plugs: If they are saucer type the recess needs to be really grease free, then a slight bead of Araldite around the edge of the plug and tap it in. Lay the block horizontally and warm the Araldite to let flow around the plug. Leave until hard and you won`t have any leaks. Most engine builders fit them like that and I`ve never had one come out or leak.
John
1600 HF. S2.
Pages: 1 ... 22 23 24 25 26 [27] 28 29 30 31 32 ... 54   Go Up
Page created in 0.044 seconds with 20 queries.
