26 November, 2024, 10:19:41 PM *
Pages: 1 ... 46 47 48 49 50 [51] 52 53 54   Go Down
Author Topic: Story so far series 1 resto  (Read 348672 times)
« Reply #750 on: 17 January, 2021, 09:29:36 AM »
Hi Clarkey
For me the individual ones look pretty awful and a definite bodge.
I actually like the look yours Mike
« Reply #751 on: 17 January, 2021, 04:42:18 PM »
Just sourced another mini rear lamp in total the 2 cost £28 plus postage so not too bad...out with the Dremel tomorrow.
mikeC
« Reply #752 on: 18 January, 2021, 08:25:53 AM »
When I was looking at changing my lamps, the minivan ones were going to be well into three figures for a second-hand pair, so you've done well there! Mine are 'all right', but they have a very square profile with sharp edges which jars with the rounded lines of the car... but it was only a passing fancy, they'll stay for now.
1953 Lancia Appia Series 1
1931 Austin Seven deluxe saloon
1914 Saxon Model A roadster
« Reply #753 on: 26 January, 2021, 08:57:23 PM »
Hi All
Oops too late now...
« Reply #754 on: 26 January, 2021, 09:01:14 PM »
What a marvellous device a Dremmel is plus the wing is aluminium so easy to cut
« Reply #755 on: 26 January, 2021, 09:06:24 PM »
A bit of work to do seating the lamp to the wing but I sourced a set of new gaskets so should be able to get a good fit.
« Reply #756 on: 26 January, 2021, 09:14:11 PM »
Bit of rewiring and I'll get the other one in 😊 the new lamp is an improvement on the boxy one and not as bright with no slot to light up a number plate as they were designed for a trailer board.
Well chuffed of Redcar
« Reply #757 on: 27 January, 2021, 03:03:46 PM »
Very nice, and I imagine very satisfying.
« Reply #758 on: 27 January, 2021, 09:00:32 PM »
Bit scary cutting chunks out of the wings... Surprised at how thick the metal is. And now we have 2 but looks like the brake light switch is on the fritz and the gaskets need a bit of trimming to make the fit better.
« Reply #759 on: 28 January, 2021, 08:24:46 PM »
Brake lights working as well as the indicator switch (it wasn't locking as the elves had been playing with screwdrivers and disconnected a wire) Will swap out the front indicator lights for some Morris Minor ones as my original ones are shot.
« Reply #760 on: 29 January, 2021, 09:07:57 PM »
And here they are...bit of rewiring and hole cutting to do but much easier than the back ones as the panel is flat. I have some new gaskets and seals on order so will soon be up and running with an orange indicator light separate from a white sidelight.
« Reply #761 on: 29 January, 2021, 09:09:33 PM »
bit more
« Reply #762 on: 31 January, 2021, 10:25:35 PM »
Well impressed with the replacement gaskets as they are very good quality...question is where do you out the clear gasket? in front of the sponge one or behind? The thick rubber one goes between the rear of the lamp and the panel.
« Reply #763 on: 31 January, 2021, 10:29:53 PM »
The picture shows the slot cut to accept the bigger lamp...
« Reply #764 on: 31 January, 2021, 10:33:14 PM »
And here is the finished look the round lamps fit in with the car's lines better than a square one I looked at (ex Mk1 Escort/Hillman Minx I think).
Pages: 1 ... 46 47 48 49 50 [51] 52 53 54   Go Up
