30 November, 2024, 10:49:34 AM *
Pages: 1 ... 41 42 43 44 45 [46] 47 48 49 50 51 ... 54   Go Down
Author Topic: Story so far series 1 resto  (Read 350038 times)
0 Members and 17 Guests are viewing this topic.
JohnMillham
« Reply #675 on: 03 January, 2020, 10:30:55 AM »
I had a similar problem with my Lambda, having to Helicoil a few stud holes. I had to hire a magnetic drill in order to be sure the threads were straight. I subsequently found adverts on the Internet for such drills, not a lot more expensive than the cost of hiring one. If I ever have to do a similar job, I'll buy a magnetic drill. By the way, I would not even consider running the engine before putting the stud in properly.
Mikenoangelo
« Reply #676 on: 03 January, 2020, 11:24:58 AM »
I'd sort it now if you can because if my experience is anything to go by you'll have no Lancia time for ages after you have moved house. Sad
Like John I'd not run it until the stud is sorted as you might ruin the gasket or have some other nasty.
Mike
lancianut666
Slow but rough
« Reply #677 on: 03 January, 2020, 01:19:23 PM »
Thanks for the wise words... I was going to offer the damn thing to a local fisherman as an anchor for his boat but I've calmed down and ordered a helicoil kit so will be back on the tools over the weekend...agree about no Lancia time after the move so will try and get the little beast up and running before it goes on the back of a trailer. Being positive it is better the problem happened now and better than when the engine was back in the car.
Clarkey
lancianut666
Slow but rough
« Reply #678 on: 03 January, 2020, 02:56:49 PM »
Hi all
The head is off and the stud out it had stripped the nut as well as coming lose... the lack of thread in the tapped hole in the block is the reason it screwed so far in and caused the problems
see picture
Clarkey
« Reply #679 on: 03 January, 2020, 06:55:09 PM »
Not sure a helicoil will solve this but a  "time sert" possibly could, and "big sert" (http://www.timesert.com/html/bigsert.html) probably would be required. What is the thread?
Wurth do a variety of Timesert kits.
nistri
« Reply #680 on: 04 January, 2020, 02:17:03 PM »
I have not tried myself to helicoil an Appia head but I don't see why not. This kind of repair can be done to Lancia alloy components. On the other hand, running with a slack fastener may warp the cylinder head and produce leakage problems. Andrea
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
« Reply #681 on: 04 January, 2020, 03:24:56 PM »
Andrea, I was looking at the top c10mm of the hole where no thread is apparent as it seems to have been abused in the past. I am surprised the engine shop did not spot this.....Tim
Kevinlincs
« Reply #682 on: 19 January, 2020, 10:07:04 PM »
Just finished reading all 46 pages, you deserve a medal for perseverance  Cool
A lesser man would have done the boat anchor by now
Flavia 815 coupe
Delta integrale
lancianut666
Slow but rough
« Reply #683 on: 20 January, 2020, 06:42:41 PM »
I must confess I have given up at the moment as we are moving house so the little beast is being trailered back up North to a more spacious and slightly warmer workshop. in the meantime I managed to revisit the 'Parallel  project' as it needed to be moved to allow the sulking Appia in!
Clarkey
lancianut666
Slow but rough
« Reply #684 on: 20 January, 2020, 07:07:23 PM »
The previous project a Flavia Coupe took ten years surviving 2 divorces,  a career change and about half a dozen moves.
Clarkey
Kevinlincs
« Reply #685 on: 20 January, 2020, 07:12:47 PM »
As I say, perseverance  Cool Grin
Flavia 815 coupe
Delta integrale
lancianut666
Slow but rough
« Reply #686 on: 21 January, 2020, 07:14:08 PM »
The Appia was last seen on the back of a trailer this morning on it's way to the unit...I'm still stuck with that flippin engine...
« Reply #687 on: 24 January, 2020, 01:43:27 PM »
Could you permit yourself a donor engine to get the show on the road and deal with the recalcitrant unit over a longer period? Or is that cheating?
lancianut666
Slow but rough
« Reply #688 on: 24 January, 2020, 07:09:11 PM »
It will get sorted...
lancianut666
Slow but rough
« Reply #689 on: 24 January, 2020, 07:10:40 PM »
The little beast arrived back at Hartlepool this morning he looks a bit cold!
Pages: 1 ... 41 42 43 44 45 [46] 47 48 49 50 51 ... 54   Go Up
Page created in 0.035 seconds with 21 queries.
