27 November, 2024, 12:28:37 AM *
Pages: 1 ... 45 46 47 48 49 [50] 51 52 53 54   Go Down
Author Topic: Story so far series 1 resto  (Read 348704 times)
0 Members and 18 Guests are viewing this topic.
lancianut666
Slow but rough
« Reply #735 on: 16 December, 2020, 06:52:09 PM »
It had a fibre one on but I set it on fire oops
lancianut666
Slow but rough
« Reply #736 on: 17 December, 2020, 10:40:18 PM »
Tank had a quick rinse with petrol and the plug put back in ...fuel line at the other end connected so I spun it over on the key to see if it would draw up some petrol into the inline fuel filter I fitted...it did! so I gave it a longer spin over and we got some bangs and pops. I thought a check of the spark was in order and it was a sickly yellow not a nice white one so will check the points next.
Clarkey
lancianut666
Slow but rough
« Reply #737 on: 07 January, 2021, 06:23:38 PM »
I have just received a box of indicator and brake lights from Chris Gawne and my eagle eye had spotted some festoon mounting lamp holders minus their lenses so I got a little farther with rebuilding the number plate lights as the originals are in very poor shape with the internal steel plate in one completly shot. So a quick trace round a piece of scrap aluminium plate and a bit of drilling and cutting Ta Dah! Bit more to do but I now have 2 newish bulb holders to fit into the number plate light castings. The badly corroded plate can be seen in the first picture as well as the seized solid cable connection. I just need to find some perspex or similar to make a lenses for each lamp. Typical Lancia the oblong hole in the middle of the plate matches up with a similar hole in the boot lid allowing I expect light to illuminate the boot when the side lights etc are on can't wait  Smiley Smiley Smiley
The second picture shows the bulb holder salvaged from the Chris Gawne hoard.
Clarkey
lancianut666
Slow but rough
« Reply #738 on: 07 January, 2021, 06:24:55 PM »
There is more
lancianut666
Slow but rough
« Reply #739 on: 07 January, 2021, 06:30:38 PM »
I might look into running a separate earth for these lamps as this will ensure a better performance rather than relying on the connection via the boot lid hinges. Also a more weather proof sealing for the lamps as I am guessing they would be a major water ingress spot for the boot when the seals are a bit tired (mine were stuck on with what looks like tar!)
Clarkey
lancianut666
Slow but rough
« Reply #740 on: 09 January, 2021, 10:50:50 AM »
Finally got one finished
lancianut666
Slow but rough
« Reply #741 on: 09 January, 2021, 10:51:47 AM »
and tested in situ
lancianut666
Slow but rough
« Reply #742 on: 14 January, 2021, 04:46:59 PM »
And then there were 2
lancianut666
Slow but rough
« Reply #743 on: 14 January, 2021, 04:49:11 PM »
While at the front...
lancianut666
Slow but rough
« Reply #744 on: 14 January, 2021, 04:51:48 PM »
Still a fair bit of wiring to do before the number plate lights are finished plus what to do about the non-existent chrome???
lancianut666
Slow but rough
« Reply #745 on: 14 January, 2021, 05:03:10 PM »
just arrived a Minivan/Traveller rear light as I want to change the boxy plastic ones...
lancianut666
Slow but rough
« Reply #746 on: 16 January, 2021, 02:48:51 PM »
The piccy shows a mock up with the minivan lenses stuck on with bluetack...problem is I will have to cut the wing to get this light fitting to fit.
lancianut666
Slow but rough
« Reply #747 on: 16 January, 2021, 02:51:23 PM »
Another view the finished job would have a chrome surround...
lancianut666
Slow but rough
« Reply #748 on: 16 January, 2021, 02:54:35 PM »
Another idea would be two separate lights like this...Any comments on this would be most gratefully received.
Clarkey
mikeC
« Reply #749 on: 17 January, 2021, 08:33:06 AM »
I think the minivan units work well. My car has replacement units which I'm not entirely happy with, and having looked at the alternatives available I decided the mini ones were probably the best solution, but decided to stick with what I had after seeing the prices they fetched! For me the individual lamps you show look too messy.
1953 Lancia Appia Series 1
1931 Austin Seven deluxe saloon
1914 Saxon Model A roadster
(previously owned Lancias: 1958 Appia Pininfarina coupe, 1987 Delta LX, 1986 Delta cabriolet, 1991 Dedra 1.8, 1993 Dedra 1.6)
Pages: 1 ... 45 46 47 48 49 [50] 51 52 53 54   Go Up
Page created in 0.038 seconds with 21 queries.
