22 December, 2024, 04:22:26 AM *
Author Topic: Fulvia running like a bag of nails !  (Read 6063 times)
HF_Dave
« on: 27 April, 2014, 07:03:33 PM »
I have developed a problem with my Fulvia, It starts up no problem and then when put under load it miss fires and chugs along. I checked the fuel flow and filters from the tank , the points , the timing and changed the spark plugs ! it ran a bit better when I changed the plugs but it s still not right. The temp wont rise to normal running temp, and then it runs smooth for no reason at all  !!  Huh?, Iif I pull the choke a little it seems to run better . Could there be a blockage in the carbs ?  Its wreching my head to fugure this out ! Any ideas ? Thanks David. Undecided
My Current Cars:
1991 Thema station wagon
1989 Thema 16v
2011 Lancia Delta 3
1977 Beta sedan 2000
1975 Fulvia S3 1.3
1973 Flavia HF 2000 Coupe
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
richardgcs
« Reply #1 on: 27 April, 2014, 07:09:14 PM »
Have you checked the "micro" mesh filter on the inlet union on rear carb ?
chugga boom
Non-LMC Seller
« Reply #2 on: 27 April, 2014, 09:16:18 PM »
I had exactly that on my augusta, gauze partially chocked so the carb would run out before it could refill
1935 augusta lusso (chugga)
1935 belna saloon
1935 augusta lusso
1938 ardenne
1939 aprilia lusso
1958 appia s2
1963 appia s3
195? appia camioncino
1972 fulvia 1600HF
1976 fulvia coupe
peterbaker
www.retro-speed.co.uk
« Reply #3 on: 27 April, 2014, 11:00:53 PM »
Condensor, its always the condenser.
neil-yaj396
Committee
« Reply #4 on: 28 April, 2014, 06:24:18 AM »
Does sound similar to the carb problems I had on my Beta. That was dirt in the float chambers, jet feeds and the jets themselves. Cleaning the jets was a temporary fix, but further dirt would then be dragged into them from the float chamber. Only a total strip and clean ou,t with everything blown through with an airline fixed it.
Easy to check out Peter's condenser suggestion though.
Richard Fridd
« Reply #5 on: 28 April, 2014, 07:19:30 AM »
Air leak?
stanley sweet
« Reply #6 on: 28 April, 2014, 09:39:49 AM »
Does sound similar to a condensor breaking down. I had something like this on my Fulvia years ago - as you say, like a bag of nails, spluttering along, running rough, and that's what it was. For the price of a new one it's worth a go
ColinMarr
« Reply #7 on: 28 April, 2014, 05:55:35 PM »
And do the points at the same time! Either fit new ones or stone-down the old ones to take out peaks and pits. The last set of points I did had massive pits, about 0.3mm deep. A defective condenser can cause this sort of migration of metal from one contact to the other.
Colin
HF_Dave
« Reply #8 on: 28 April, 2014, 08:28:10 PM »
Thanks for the advise, I fitted a new coil and HT leads today and its running perfect Cheesy, Amate of mine suggested the coil and i got a Bosch one and replaced the Intermotor one that was bought new in 2009 while I was restoring the car. I thought I was covering all the bases by replacing everything at the time, but time goes by very fast and five years has gone by in a flash. I am going to replace the distributor with a new electronic one from Omicron . Has anyone tried this replacement yet ? it's expensive at 280 plus vat , but the car has cost me very little since the restoration . Thanks. David. Smiley
My Current Cars:
1989 Thema 16v
2011 Lancia Delta 3
1975 Fulvia S3 1.3
1972 Fulvia S2 1.3
1989 Thema 8.32
**Other Makes**
2018 Alfa Giulia
1999 Alfa 156
2009 Fiat Du
Page created in 0.043 seconds with 20 queries.
