21 December, 2024, 03:37:29 PM *
Pages: [1] 2   Go Down
Author Topic: Fulvia Fuse Ratings  (Read 13000 times)
« on: 02 June, 2014, 09:29:40 AM »
Perhaps I'm a bit thick this morning, but what are the ratings for the
White
Red,
Blue
fuses, please.
Dilambdaman
« Reply #1 on: 02 June, 2014, 09:58:38 AM »
Here you go Brian.
Bosch type fuse (used in older cars)
Bosch type fuses (also known as torpedo, ATS, or GBC type fuses) are used in old (often European) automobiles. The physical dimension of this type of fuse is 6×25 mm with conical ends. Bosch type fuses usually use the same color-coding for the rated current. The DIN standard is 72581/1. The size of the fuse is: 6×25 mm.
Color coding[edit]
Color   Current rating
 Yellow   5 A
 White   8 A
 Red or
 Green   16 A
 Blue           25 A
 Grey or
 Black   40 A
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #2 on: 02 June, 2014, 11:27:44 AM »
Black can be 8 or 16 too!!
Most I have seen are moulded with rating in small chars on reverse. Need a magnifyer if long sighted....
« Reply #3 on: 02 June, 2014, 11:48:31 AM »
Thanks Tim,
Just looked again, ( I knew I wasn't with it this morning Roll Eyes) and the blue fuse has 25 A stamped on the metal strip?
What do you reckon it would be safe to use for the horns as a temporary measure, my fuse holder has always had a white fuse in this position which at 8a seems a bit low, this is the one I've started blowing, but as the weather hasn't been good I haven't been able to get out and check connections etc.
« Reply #4 on: 02 June, 2014, 12:36:05 PM »
Reminds me of a story I read on the "Darwin Awards" about an American country boy who had a pick up that kept blowing a fuse. So he ended up using a rifle cartridge instead. Needless to say that blew too.
If a fuse blows there's a reason and I wouldn't use anything bigger in the circuit than originally intended. You may have a weak link in the chain that's weaker than the fuse and that might result in the smoke escaping. Unlike Lucas wiring Magnetti Marelli don't supply aftermarket smoke so you'd have a real problem  Grin
If it's blowing I think you need to find out why. Try replacing sections of wire between the fuse, connectors, horn etc until you identify which part is causing the problem?
« Reply #5 on: 02 June, 2014, 01:06:21 PM »
Measure resistance?
David
« Reply #6 on: 02 June, 2014, 01:18:48 PM »
Thanks Guy,
It's just that I wasn't sure what should be there in the first place Huh?
I've just got out my handbook that states " Nine fuses 15A protect the various circuits, as indicated on the cover of the fuse box".
Beggars the question 15A fuses? as this value doesn't seem to be available, nearest being the red 16A, I shall have to have a look, real faf of a job on Berlina as it's behind the switch panel in the centre of the dash, unlike coupes.
I have a spare in my loft so I think I'll get that down and see what fuses that has in it.
« Reply #7 on: 02 June, 2014, 07:08:40 PM »
I would fit a 16A all through the fuse bay. Higher ones are generally in separate fuse holders...
Dilambdaman
« Reply #8 on: 02 June, 2014, 09:46:10 PM »
Fanalone runs happily on red 16A fuses.
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
« Reply #9 on: 02 June, 2014, 10:29:31 PM »
Robin.
Thank you Gentlemen, I'll try 16A fuses throughout.
Very interesting as I've been checking out my spare fuse box and found that 8 circuits were fitted with white 8A fuses, while the 9th the horn circuit in question has a 25A blue fuse fitted, this circuit has about the heaviest cable (Red) that goes to the Ignition Switch; I just wonder why my spare fuse box and the one in "Fay" have a preponderance of 8A fuses fitted???
Another interesting point but probably a useless observation is that the Blue fuse I have with the rating on the strip seems to be a more modern version, and it's length is 26mm, whereas the blue fuse with the rating moulded into the ceramic body, seems to be more like 24.5mm rather than 25mm.
« Last Edit: 02 June, 2014, 11:10:12 PM by fay66 » Logged
Dilambdaman
« Reply #10 on: 03 June, 2014, 08:35:52 AM »
S1 Instruction Book states;  " Nine fuses (15A) protect the various circuits"
Robin.
Robin Lacey 3222
1932 Dilambda
1992 Y10 GTie
2012 Delta Mk3
2013 Ypsilon 846
nistri
« Reply #11 on: 03 June, 2014, 09:03:04 AM »
The horns always take a lot of current. In fact, if one wishes to know the battery condition, a blip on the horn is a quick method to discover a weak battery if the sound is poor. Andrea
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
« Reply #12 on: 06 June, 2014, 10:38:55 PM »
Nice day today so I pulled the switch panel and replaced the fuse in question with a 16A fuse, everything apart from 1 door edge warning light, but as the interior light on the same part of the circuit works it's probably a bulb.
I also looked at my engine compartment light that isn't working, a quick check with a probe established that there was power to the bulb holder and the probe light also lit on the other side of the bulb holder, even though the festoon bulb itself didn't light up, visually the bulb element was intact, so why doesn't the bulb light up?
« Reply #13 on: 07 June, 2014, 11:59:14 AM »
I just changed a bulb in the everyday car that looked fine but didn't work.  I spent a grumpy couple of minutes thinking it was the holder or a wire before doing the obvious test.
All we can say is "it happens"...and ensure it goes straight in the bin rather than getting confused with the spares.
Got a known good bulb to test with?  Tested that bulb with a couple of wires direct to the battery?
David
« Reply #14 on: 07 June, 2014, 04:38:19 PM »
David
Thanks David,
I'll give it a try.
Pages: [1] 2   Go Up
Page created in 0.033 seconds with 21 queries.
