Further to my starting problems after leaving the car for a week or so, I have finally cured it this week.
I spent some time thinking (Honest) about the problem, and decided that as the fuel line in the engine bay runs upwards to my in line filter before going on to the carb, the fuel was draining out of the filter back down the fuel line, which was causing a negative pressure in the fuel line between the filter and carb, which was causing the fuel to be siphoned out of the float bowl.
Hence, when I attempted to start it after some days, it would churn and churn until the fuel was pumped up to the filter and then the carb, and then fire. after that of course, it fired instantly.
So, I simply fitted an in line one way valve between the filter and carb so that it wouldn`t drain the float chamber, even though the fuel filter was drained empty when I checked, and hey presto it started almost instantly after sitting for 2 weeks ! So problem (For me anyway) solved.
Now, how about having Omicron fit one of their electronic ignition systems to it, any thoughts chaps ?
Bob
Bob
