27 December, 2024, 12:45:56 PM *
Author Topic: Snubber springs - beware!  (Read 4136 times)
« on: 18 June, 2014, 11:16:07 AM »
The port side front suspension on Old Boot had taken to getting jammed on full extension.  "Worn bottom guide" I thought and went to take it off.  It will not come!    I cut off the bottom half of the guide and discovered that the snubber spring had broken up and slightly expanded the lower 5 mm or so of the king pin (by some 20 microns).   This is going to take some very careful work with a Dremel to reduce the high bits and get the upper half of the guide off.   I shall then proceed to replace the snubber springs on both cars and suggest you all do the same.  After all, they are more than 80 years old!
« Reply #1 on: 22 July, 2014, 06:49:56 PM »
I managed to get the guide off by cutting almost through it vertically and the tapping it down when it obliginly split.  Not a madk on the pillar either!   However, next problem is removing the pillar/stub axle assembly as I have decided that Dremelling will not do a good job and the pillar needs to be ground down to size.   I made up a collar so as to extract upwards using the part H4 as the Book of Words says blandly "remove the ring H2 and take our H and M".  M is the inner sheath and H the screwed bit.  I have tightened as much as I dare and even tapped cautiously but so far no joy.    Thought has struck - is it screwed in?  Does not look to be so on the Tavola but before I apply heat I thought I'd ask if anyone else has done this.   I did change a stub axle some years ago but cannot remember how I did it!
« Reply #2 on: 22 July, 2014, 07:45:04 PM »
ps what is a "snubber spring" ?
« Reply #3 on: 23 July, 2014, 08:49:03 AM »
Spring in the bottom of the lower guide, takes the impact of the descending pillar.
Page created in 0.069 seconds with 21 queries.
