21 December, 2024, 01:47:04 PM *
Author Topic: Delta 1.6 i.e. idling problem  (Read 6068 times)
« on: 16 July, 2014, 11:22:02 AM »
Anyone know about the Delta bosch i.e. system?
My car starts and idles from cold fine. However, it stalls every time it comes off revs (so when it comes to a junction). Restarts fine and idles although it hunts between 500 and1200 before settling to c1000 ( on the rev counter).
When hot or cold it does the same thing. It also runs fine when not at idle.
Before I try looking at all the sensors can anyone suggest anything?
« Reply #1 on: 16 July, 2014, 05:19:33 PM »
Tim,
Try cleaning the idle control Valve, and the throttle switch that attaches to the butterfly at the intake, as they tend to get gummed up with petrol deposits.
« Reply #2 on: 16 July, 2014, 06:35:55 PM »
Try the connections on the temperature sender, these can sometimes cause an erratic idle.
« Reply #3 on: 17 July, 2014, 07:37:35 AM »
Ta for thoughts.
Seems the throttle position sensor is sensitive to "throttle closed" position for something to create a "soft tickover point" in the ecu. The TPS on my car had worked loose and by trial and error I think I have found the correct setting. Time will tell.
« Reply #4 on: 23 July, 2014, 07:02:30 AM »
After a number of attempts to get a stable tick over it seems that the Trottle Position Sensor (TPS) which is a quite large potentiometer fitted to the throttle spindle is worn and does not give reliable results at the zero to 100ohm part of its operation.
I am putting a call out for anyone who may have a replacement they could sell me. It is a Weber PF09.
Also has anyone had experience of fitting an Intermoter replacement?
rogerelias
MY 1600HF IN HEARTBEAT GARAGE
« Reply #5 on: 23 July, 2014, 11:28:32 AM »
See note under spares required Smiley
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
Triumph Bonneville t120v 1972
1968 MGC ROADSTER
1958 Series 2 Appia berlina
Page created in 0.044 seconds with 20 queries.
