26 December, 2024, 07:27:49 PM *
Author Topic: Aurelia B20/B24 Nardi kit with or without Weber 40DCL/Z carburettors  (Read 4471 times)
« on: 07 January, 2015, 02:17:25 PM »
When I am back in mid February I intend to advertise the following on ebay. I will most likely offer the carburettors separately and put all the Nardi manifolds, gaskets, studs, linkage, petrol pipe and one airbox together as one lot.
1. A complete set of unused replica Nardi twin Weber carb inlet manifolds + bridging manifold for B20/B24 with all studs, gaskets fully machined and finished.
2. An used ORIGINAL throttle linkage for the above. The design of this and the above manifolds etc can be clearly seen on the Cavalitto website www.oldlanciaspares.com .
3. I have available used ORIGINAL Nardi cast aluminium airboxes of both types - i.e deep narrow and wide shallow illustrated in the attached photos lifted from an earlier post about Nardi cast aluminium airboxes (thank you for the photo Sebastien) - together with the 8 special fixings to attach these to the 4 studs on each carb. I also have an unfinished, unpolished, undrilled  replica Nardi 'wide, shallow' airbox casting with a new black mesh air inlet filter if someone would like to finish this off and save money.
4. With the above I can supply either (or both) a used Weber 40 DCL and a used Weber 40 DCZ carb with standard jets (alternative jets are readily available) . Both of these are complete, in full working order and photos are attached.
The 40 DCL has good shafts with minimal wear, good quadrants, new butterflies and several new parts fitted. It has had a repair to the float chamber cover in the area of the fuel connection. It has also had a repair to one of the float chamber cover bolt threads and one of the slow running air needle valve threads but is in full working order. The original makers plate was missing when I bought it so a replica plate is fitted.
The 40 DCZ also has very good shafts with minimal wear and is totally original and complete  in good working order.
5. I also have a used ORIGINAL rigid fuel feed connection pipe for twin Weber Nardi for B20/B24.
If required I can also supply an unused fully reprofiled  'fast road use' B20/B24 camshaft.
I am not really sure about prices for any or all of the above but there appears to be no sign of new 40 DCL/Z type carbs being made. Feel free to contact me if you have any serious interest in any or all of the above before I resort to ebay in mid Feb
« Reply #1 on: 08 January, 2015, 10:50:56 AM »
Carburettors, linkage, airboxes and Nardi manifolds all sold!!
« Reply #2 on: 08 January, 2015, 11:24:41 AM »
Not surprised !
Page created in 0.051 seconds with 20 queries.
