23 December, 2024, 11:37:23 AM *
Author Topic: Help! Fulvia 3 wiring diagram needed...  (Read 5343 times)
RobD
« on: 21 July, 2015, 04:48:46 PM »
Would anybody have , or can somebody point me in the direction of a Fulvia 3 wiring diagram. I'm specifically looking for alternator/regulator/ignition light wiring connections.
Thanks in anticipation,
Bob
'75 Fulvia 1.3S
'68 works Laverda 125cc ISDT
KTM 640 Adventure
Yamaha TDM 900
www.adventureride.co.uk
« Reply #1 on: 21 July, 2015, 06:45:10 PM »
Hi Bob, I have diagrams, I'll mail some over later, sounds like you don't have handbook. Neil
386
1973 Fulvia S2 1.3
RobD
« Reply #2 on: 21 July, 2015, 07:06:28 PM »
Neil,
 I do have a handbook and guess what I've just discovered lurking in it? A veritable cornucopia of wiring diagrams! Doh...
Many thanks for pointing that out so politely... and no need to mail anything across.
All the best , Bob
'75 Fulvia 1.3S
KTM 640 Adventure
Yamaha TDM 900
« Reply #3 on: 21 July, 2015, 09:12:57 PM »
Check type of alternator for specific wiring as Bosch is different to Ducillier....
« Reply #4 on: 21 July, 2015, 09:23:27 PM »
No problem, at least you found it,  the Ducellier alternator has the regulator under the wing, near the horn and cooling fan relays.
386
1973 Fulvia S2 1.3
RobD
« Reply #5 on: 22 July, 2015, 07:19:11 AM »
Thanks chaps,
My car's got a Ducellier, which has been checked by a specialist and is in good health, I've got a fresh battery and a new regulator from Omicron but for some reason I've still got charging issues. I suspect the new reg may be faulty but I've conceded defeat on this one due to lack of time not to mention my ineptitude with a multi meter and dropped it off at the local garage. Their electrician asked for a wiring diagram so he could sense check the various connections .
'75 Fulvia 1.3S
KTM 640 Adventure
Yamaha TDM 900
« Reply #6 on: 22 July, 2015, 09:02:05 AM »
Thanks chaps,
i think I mentioned a 2cv regulator available for peanuts is correct aftermarket part for the Ducillier. Also there is a small (green?) wire that goes onto a spade terminal at the back of the Ducillier which if not connected will give no charge output but the red light stays off.....
RobD
« Reply #7 on: 22 July, 2015, 11:33:51 AM »
Mmm...Tim, the green wire sounds as if it could be a contender. The wiring under the bonnet is an 'orrible mish mash of spliced in connections and jury-rigged modifications and bodges. During the winter I will hopefully address these problems but in the meantime I'll have to patch and mend.
'75 Fulvia 1.3S
KTM 640 Adventure
Yamaha TDM 900
« Reply #8 on: 04 August, 2015, 08:51:13 PM »
Might be a good idea to post the diagram on the technical information thread.
