30 December, 2024, 02:50:47 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Lancia Motor Club
Model Technical and Interest
Fulvia
Series 1 Zagato - Blown no 3 fuse issue!
Pages: [
1
Go Down
« previous
next »
Author
Topic: Series 1 Zagato - Blown no 3 fuse issue! (Read 3574 times)
libbyvic
on:
08 August, 2015, 04:07:52 PM »
Hi All, I wonder if you can help with this one. My fuse no 3 on my Fulvia series 1 zagato is continually blowing. Things that are not working are as follows;
Horn does not work
Headlamps work on side light and full beam only. It seems the headlamp solenoid does not click to take the lights onto main beam.
Clock now stopped.
I have taken out the light switch and ignition to see if any wires are touching but no obvious connection.
Fuse still blows with the horn relay disconnected and the horn.
Does anyone have a headlamp solenoid and light switch for me to buy and try, or anything else I can try to ID the issue?
Many thanks,
Michael
1968 Fulvia Sport S1 Zagato
libbyvic
Re: Series 1 Zagato - Blown no 3 fuse issue!
Reply #1 on:
08 August, 2015, 04:14:21 PM »
Sorry meant to say Headlamp relay, not solenoid.
Reply #2 on:
08 August, 2015, 05:11:14 PM »
I had his problem - turned out that the stop light switch had come adrift and was shorting its terminals from time to time. Worth a look - it is attatched to the brake pedal mount in the footwell...
libbyvic
Reply #3 on:
08 August, 2015, 05:30:32 PM »
Had a look but my brake stop switch is on the back of the brake master cylinder. Is that the one you mean?
Reply #4 on:
11 August, 2015, 11:46:22 AM »
An interesting problem as the light relays on the Zagato are of course different from the coupe because there are no four lights to turn on in various combinations. Note that in the Fulvia the light contacts are always connected live on even when switched off and they are turned on by putting the circuits to ground. Thus, it is worth checking very carefully for stray contact concerning the lights and the relays which can be opened with a bit of care (make a detailed diagram), cleaned and refitted for full service. It is also worth remembering that the horn takes the maximum amp current in the whole circuit, in fact to test the battery charge it is often enough to try the horn and hear it loud. My bet is on the light circuit. Good luck, Andrea
Reply #5 on:
11 August, 2015, 01:09:28 PM »
Quote from: libbyvic on 08 August, 2015, 05:30:32 PM
Mine is a mechanical one, yours is hydraulic so not the culprit.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
