26 December, 2024, 09:50:20 AM *
Pages: [1] 2   Go Down
Author Topic: Tyre Pressure for Michelin XAS  (Read 14728 times)
nthomas1
« on: 13 August, 2015, 09:59:59 PM »
From experience, what is the optimum tyre pressure for Michelin XAS tyres on standard S2 Coupe steel rims - for normal driving with one or two on board?  Thanks in anticipation, Norm
Norm Thomas
Ormskirk, Lancashire
Own:
1973 Fulvia S2 Coupe
« Reply #1 on: 14 August, 2015, 07:06:25 AM »
Around 24psi all round. Are they new rubber?
nthomas1
« Reply #2 on: 14 August, 2015, 07:24:35 PM »
Thanks for the response.   Based on appearance I'm guessing they were fitted in the last 12 to 18 months.
Norm Thomas
Own:
« Reply #3 on: 14 August, 2015, 07:28:46 PM »
If they squeal round the round abouts they may be a bit older Wink
rogerelias
MY 1600HF IN HEARTBEAT GARAGE
« Reply #4 on: 14 August, 2015, 08:01:34 PM »
look on the sidewall and you may see numbers like  2314 or similar in small numbers, which means tyres were made the 23rd week of 2014,
FULVIA 1600HF LUSSO
1958 VELOCETTE MAC
Triumph Bonneville t120v 1972
1968 MGC ROADSTER
1958 Series 2 Appia berlina
« Reply #5 on: 15 August, 2015, 08:35:06 AM »
According to the handbook, 1.5Kg/sq.cm = 21.3psi to 1.7Kg/sq.cm = 24.1 psi for long runs fully loaded at high speed front and rear.
nistri
« Reply #6 on: 24 August, 2015, 06:23:48 AM »
If the  tyres were made recently, they may need a much higher pressure (usually 2 bar).
Andrea
Andrea Nistri
Ardea S2
Appia S2
Fulvia GTE
Fulvia Sport 1.3 S
Fulvia Montecarlo
Fulvia Coupe 1.3 S
the.cern
« Reply #7 on: 24 August, 2015, 09:17:20 AM »
I had noticed that, in general, required tyre pressures tend to higher now compared with say 30 or 40 years ago. Way back then, 24psi would be fairly standard, whereas now, as Andrea has suggested, 2bar (29psi), if not higher, say 2.3bar (34psi) seems routine.
Is anyone able to shed some light on this shift please?
                                                       Andy
John B
« Reply #8 on: 24 August, 2015, 09:46:01 AM »
Would it be anything to do with the change from cross ply to radial ply tyres?
1961 Appia S3
1969 Fiat 850 Special
« Reply #9 on: 24 August, 2015, 11:01:49 AM »
Most likely due to side walls being lower profile on more modern tyres. So if running non standard lower profile tyres like I do I tend to go to 2bar.
Cant remember when Lancia stopped fitting crossplies but it must be pre Aprilia.
Neil
« Reply #10 on: 24 August, 2015, 11:47:45 AM »
Tim, I think you are right, Fulvia always had radial tyres, but they would have been 82 series, today only 80 series tyres are generally available, which are marginally lower profile:  2Bar (~28psi) works well in my experience.
Neil
386
1973 Fulvia S2 1.3
JohnMillham
« Reply #11 on: 24 August, 2015, 01:40:49 PM »
The first Michelin Xs were fitted to Aurelias, so well after the Aprilia. See Longstone Tyres website, where there's a bit of tyre history.
Regards, John
« Reply #12 on: 24 August, 2015, 05:37:47 PM »
When I bought "Fay" she had what I believe was the original 155,14,x80 Michelin X's fitted, as she'd only done 27,000 miles with the original owner, and it looked like the spare had only been used lightly.
« Reply #13 on: 25 August, 2015, 07:00:13 PM »
Agree, Aprilias were originally cross ply but Michelin X suited them very well.  Now universally on radials I suspect.  Agree also, 22 psi on my Fulvia means impossibly heavy steering with modern tyres.  Currently at 28 psi but tempted to go higher...
« Reply #14 on: 25 August, 2015, 10:40:36 PM »
David,
The new Dunlop Street Response  i've just fitted to my 2c are very good once the wheels are moving, even very slowly, so I have no complaints
I run 28psi all round.
Pages: [1] 2   Go Up
Page created in 0.038 seconds with 21 queries.
