21 December, 2024, 12:17:56 PM *
Pages: 1 ... 6 7 8 9 10 [11] 12 13 14 15 16 ... 31   Go Down
Author Topic: my new integrale  (Read 192921 times)
« Reply #150 on: 16 July, 2018, 09:16:37 PM »
A lot to take in for one night, I promise to try some more if there is an appetite for it?
I'm starving! More please!
Kevinlincs
« Reply #151 on: 22 July, 2018, 09:29:45 PM »
With the work to the rear 1/4 to bumper areas (for which I needed to keep mounting the bumper itself) now done I could at last get the car on the tilter frame.
This means bolting a frame front and rear to the car which then mount onto A frames each end which then allow the car to rotate through 360 degrees, full rotation so you can weld at whatever angle you need.
This frame I've used on a few AlfaSuds so thought it could easy enough be adapted to suit the Delta?
Sorry for the poor quality 'phone pictures...
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #152 on: 22 July, 2018, 09:31:25 PM »
Rear end awaiting lifting onto frame..
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #153 on: 22 July, 2018, 09:36:00 PM »
Tiltable to any angle...
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #154 on: 22 July, 2018, 09:37:11 PM »
Roof just clears the floor by a few inches...
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #155 on: 22 July, 2018, 09:40:39 PM »
The reason for turning the car upside down was to gain better access to the rear suspension turrets and make the repairs much easier.
This was what was left of the inner rear arch and strut top to fathom out...not pretty!
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #156 on: 22 July, 2018, 09:43:09 PM »
Majority of the strut mount was OK, just the side return section needed cutting out. This is also the piece that's inside the car towards the inner C pillar near the seat belt point, mine was the fully floating type!
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #157 on: 22 July, 2018, 09:44:51 PM »
A repair piece was made up from the same thickness 2mm steel as the rest of the tower.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #158 on: 22 July, 2018, 09:46:16 PM »
As viewed from inside the car...
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #159 on: 22 July, 2018, 09:49:07 PM »
Joining section for the inner C pillar, again the access to repair was much easier on the tilter frame.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #160 on: 22 July, 2018, 09:50:46 PM »
Reunited!
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #161 on: 22 July, 2018, 09:53:27 PM »
The inner rear arch was another item that I had little idea of what it should look like as there was nothing much to remove!
Simplest option was to start building it up in manageable sections..
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #162 on: 22 July, 2018, 09:57:08 PM »
The section for under the arch itself was a bit more tricky, it needed to follow the contours of the outer arch closely to be a tight fit to weld but made from strong enough steel to be usefully strong.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #163 on: 22 July, 2018, 09:59:09 PM »
All welded in, not the prettiest but solid again.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #164 on: 22 July, 2018, 10:00:32 PM »
At last, no view of the road through the rear light opening!
Flavia 815 coupe
Delta integrale
Pages: 1 ... 6 7 8 9 10 [11] 12 13 14 15 16 ... 31   Go Up
