21 December, 2024, 02:31:25 PM *
Pages: 1 ... 13 14 15 16 17 [18] 19 20 21 22 23 ... 31   Go Down
Author Topic: my new integrale  (Read 192943 times)
Kevinlincs
« Reply #255 on: 28 October, 2018, 05:05:34 PM »
AS my wife says of me, you seem to have an unquenchable thirst for new and more exotic ways to experience rust!
 Cheesy Very true Frank  Grin
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #256 on: 13 November, 2018, 09:41:13 PM »
The car did eventually get primed, etch primer first then a few coats of this thick 2K filler primer I like to use as it goes off fairly quickly and gives plenty of depth to be flatted off to level any minor deviations or scratches.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #257 on: 13 November, 2018, 09:42:25 PM »
Under bonnet got the same treatment, more awkward areas to rub down!
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #258 on: 13 November, 2018, 09:44:25 PM »
Important once all the primer is flatted off to spend time taking the old masking paper off and doing it again, the dust that is on this paper would blow off when you paint and make a right mess!
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #259 on: 13 November, 2018, 09:47:21 PM »
As painted, is more red than the 'phone camera shows...
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #260 on: 13 November, 2018, 09:48:14 PM »
Engine bay looking much smarter
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #261 on: 13 November, 2018, 09:49:35 PM »
The repairs to the rear roof have come out well.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #262 on: 13 November, 2018, 09:50:52 PM »
Likewise the front windscreen scuttle top change has blended in very nicely.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #263 on: 13 November, 2018, 09:53:54 PM »
The arch extensions and repairs to door openings look better than they did.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #264 on: 13 November, 2018, 10:01:37 PM »
The car then got moved out so the remaining panels could be looked at.
Hatchback had the familiar rust in the corners, no big surprise!
Outer corner repaired with a new lip
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #265 on: 13 November, 2018, 10:04:33 PM »
Inside needed a few repairs too...
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #266 on: 13 November, 2018, 10:07:40 PM »
Drivers door bottom had the usual issue under the seal retaining strip...
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #267 on: 13 November, 2018, 10:09:07 PM »
Hole cut out, new patch made up ready to go in
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #268 on: 13 November, 2018, 10:12:03 PM »
Strong again.
Flavia 815 coupe
Delta integrale
Kevinlincs
« Reply #269 on: 13 November, 2018, 10:13:59 PM »
New seal retaining strip made up and welded in.
Flavia 815 coupe
Delta integrale
Pages: 1 ... 13 14 15 16 17 [18] 19 20 21 22 23 ... 31   Go Up
